Home > In Car Electronics > Wiring in LEDs to interior lights [It's finished!] |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20465 |
99% done now bar cable tidying and connecting up one last thing. Shall put some photo's up in the next day or two.
Although my camera doesn't pick up the light quality and colour very well at night. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
8th Jun 2013 3:01pm |
Done. A few photo's below. The rest can be found Here on page 6 & 7.
Click image to enlarge Click image to enlarge Click image to enlarge I'm very pleased with it. Also all functions match the interior lighting and functions. Un-lock it and it comes on / open a door. Auto dimming. You get the picture all the interior functions are matched. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
10th Jun 2013 9:47am |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
They look great mate CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
10th Jun 2013 10:04am |
Cheers Chris. Took plenty of work to do with my electrical OCD. No Guts, No Glory.
10th Jun 2013 10:08am |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 511 |
Very nice job, Steve.
Err, carpets need cleaning, now you've highlighted them Cogito ergo sum |
10th Jun 2013 10:29am |
Thank-you. No carpets in mine all rubber matting. Mats need tipping out though.
I actually hate carpet. Mud and dogs and carpets do not mix. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
10th Jun 2013 11:07am |
Did some testing whist I fitted it all just to check everything is present and correct. Just as well I did as you can see from the door handle LED's with parallel wiring and series.
And that I added an in-line fuse as I blew it as the cable got pinched up by the headlining once. (despite being careful) All in all really happy though. I still have a couple more subtle ideas for it though but won't be making it like a Christmas tree! Testing results: Click image to enlarge No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
16th Jun 2013 5:43pm |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 |
well I also did this mod with white LED's i connected them via the ALARM and door connectors . I took switching power off from the roof liner light. The weird thing about that light is that is Negative switched ! So there is always 12v + there. So I ran a cable from there with the switched 12 - and put them on the 12v - of the LED strips. and ran a cable from the battery to the strips with constant 12v + Now my footwel area are lighted when I : Unlock and open the doors. I can manually turn them on with the roof liner light switch . They also use the Condensator's dimming , and it looks stunning. Im thinking about doing the same thing as you , but with white LED's in doors . and they have to be realy dim , not distracting. Im only afraid to pull my door out Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
26th Aug 2013 8:06pm |
The door cards aren't much to worry about believe me. Just be firm but gentle once you've taken one of the second is easy as pie. It's easiest if you have a general trim tool to do it with though. And yes, the interior lighting system is indeed a little different and isn't something to be messed with without knowing exactly what your doing and how your going to use it.
You could also use the system for "puddle" lights if they are LED and under the power consumption threshold. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
26th Aug 2013 9:01pm |
Fitted these little beauties today:
Click image to enlarge Click image to enlarge SMD LED's this time instead of the rubbish regular type I had before. I want happy with their output, I found the footwell light strips were far brighter than the actual interior lights. The last regular dome type LED's I'll ever have, SMD's all the way, much brighter! There is white available too if anyone is interested, at least I think there is. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
7th Dec 2013 3:45pm |
Where did you get them from mate? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
7th Dec 2013 5:48pm |
Here http://www.ebay.co.uk/itm/161046285976?ssP...1497.l2649
Cost peanuts too, they are the correct size too more or less. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
7th Dec 2013 6:35pm |
TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449 |
Looks great mate well done. Those SMD led bulbs are a big improvement over the older style. I have a white one in my number plate light and it's been in for 2 years and going strong! 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
8th Dec 2013 8:03pm |
Dan - I'm glad you say that because I bought some SMD number plate bulbs which are due to arrive Monday probably. What I like is that the light is spread and not directed to a point.
Thank-you for the compliments, it took a lot of head scratching fiddling and testing. wouldn't be without now especially the footwell strips. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
8th Dec 2013 8:07pm |
