![]() | Home > In Car Electronics > Wiring in LEDs to interior lights [It's finished!] |
I ended up with quite a few scribblings too.
![]() Your diodes will need to be the same wattage as the incandescents obviously to maintain circuit impedance. ![]() Treat every day as if it is your last....one day you will be right!! |
Morning Steve,
Which is virtually impossible to do unless you festoon your vehicle with enough LEDs to resemble Santa's friggin' Grotto. It was just the mention of maintaining the BBUS circuit impedence that got me my pen, paper and calculator out for you. I don't think you've any worries whatsoever. ![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20759 ![]() ![]() |
Mal you make me laugh.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Will keep the thread updated with progress in due course. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Mal - Sorry for all the questions, but do you think it would be worth fusing this with say a 2A fuse (I have some to hand) currently I haven't fused it as I've used 11A rated wire and the interior lights are 10A fused anyway. But would it be a good idea do you think to put in a lower rated 2A fuse in? By this I mean in-line to the circuit I'm adding not back at the fuse box....
Steve WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Done a little more today but not fully fitted quite yet.
The majority of the photo's can be found on page 2 & 3 Here. I can tell already I'm going to have fun routing the cables I know that much. ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Steve not sure of the final configuration for your circuitry but by using the following formulas you can work out the best fuse for your use. Power (Watts) = Voltage (12v obviously) X Current (Amps) Therefore by transposing the above you can work out the others. For example Power divided by voltage = current and power divided by current = voltage. The same rules can be applied to this formula too.... Voltage (12) = Current (Amps) X Resistance (Ohms) In both cases you only need two values to work out the third. ![]() Sorry if this is teaching you to suck eggs but they are the most useful formulas and I put them to 'good use' many times each week in my job. ![]() Treat every day as if it is your last....one day you will be right!! |
Quite the opposite Mal it's useful info to learn actually.
![]() In theory I am trying to say that say a 2A fuse will blow before the 10A thus leaving the interior lights still working but cutting the power to the items I'm adding. Protecting what I'm adding separately. Am I correct in thinking this? ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Yes spot on!
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
You've got your work cut out ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
![]() Well at least you can't say I'm trying to bodge it Mal. ![]() ![]() Think I will try and get a prewired better quality one I think. ![]() *edit* I could go down to a 1A fuse really but I can't find 1A standard blade fuses too easy and the in-line glass cartridge type's and holders I'm not really a fan of. Had one previous and binned it as the little ferker kept on giving a poor connection and causing problems as the holder was loose. ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ Last edited by custom90 on 3rd May 2013 10:18pm. Edited 1 time in total |
Before you start passing comment anyone notice Killer keeping out of the ICE / wiring threads. I don't think it's his favourite subject. ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
![]() ![]() Steve if you've a Maplins in your area they do quite good in-line 20mm fuseholders, no soldering involved just a small screwdriver needed. They'll have the fuses too. ![]() Treat every day as if it is your last....one day you will be right!! |
I do indeed Mal. One tiny one in Bath and awful to get too.
![]() Do you have a link at all? ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
![]() Waterproof here but not 20mm http://www.maplin.co.uk/search.aspx?menuno...useholders Second one in this link 20mm http://www.maplin.co.uk/in-line-fuse-holders-418 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 4th May 2013 2:58pm. Edited 1 time in total |
