![]() | Home > In Car Electronics > Wiring in LEDs to interior lights [It's finished!] |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
Some more photo's of the weekends work up here on page 4.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Shall be doing some more work on this in the next week or two. Once bits and pieces eventually arrive.
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
Argh, this just reminded me I should have posted up a couple of pics, sorry Steve.
I'll put 'em up anyway if someone is thinking of the doing the same. [URL=] ![]() Click image to enlarge[/URL] The wire goes from the door through the rubber conduit, up and out of the hole for the interior light switch and sits behind the rubber trim. The interior light switch pops back in no problem as there is plenty of space for the cable and switch body. [URL=] ![]() Click image to enlarge[/URL] Job done and no cable in sight :) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
I did think of that but my worry would be the wires chaffing on the body where it is effectively crushed between the switch and body. (Unless I am missing something) It's also not an option to have the switch loosely fitted as it's the earthing point for the doors so a poor earth will mean problems with the alarm system.
All in all as I have got it currently I am more than happy with. At least both options avoid drilling. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Rustybox has some natty blue ones fitted in his TD5 they do look cool.
![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 28th May 2013 11:08pm. Edited 1 time in total |
Had a drink Mal?
![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Long day!
Harris110 Member Since: 31 Dec 2011 Location: Wormley Posts: 14 ![]() ![]() |
This thread has got me thinking. Passengers always struggle to find the handle and something like this might be quite cool. Any thoughts on running a timed relay off the hand brake switch? Its not how fast you go, it's how little you slow down!
Yep, That would work or tap a relay off of the lighting cirucit? You'd only need it in the dark anyway so would make sense.
I'm personally going for power off of the interior lighting system but wouldn't be ideal for your intended use. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Another idea perhaps is use a standard relay and earth trigger it via the hand brake. Take your power from the lighter socket so it's ignition switched and also use the same power for the relay trigger. but connect the relay earth trigger to the handbrake.
So on a standard normally open 4pin relay: 30 lighter + 87 LED's + 85 To handbrake switched - 86 lighter + ___________________________________ 30 & 86 have the same power source. Handbrake being the switch. (This is assuming it is possible to use the handbrake in this way***) WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Hoping to have a pop at fitting in my wiring today if I get the chance or at least routing it. I shall see if I can put it in without removing the head lining after all. If at a later date I want to or have to remove it I don't want to have to take the headlining out every time to do so. There is a nice recess between the top of the door rubber and headlining that holds a couple of small wires well which is where my BT mic wire runs.
Here's to hoping a little stiff wire will do the trick. ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
All gone well so far so good. Not finished yet though.
Well progress of above I finished that day and that can be seen on page 5 & 6 Here.
More done since though will probably put those photo's up later too. Taking time to get things just right along with having limited time to touch it. Very pleased so far though. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
