![]() | Home > Puma (Tdci) > HELP no headlights. |
Kev stephenson Member Since: 27 Feb 2012 Location: Huddersfield Posts: 56 ![]() ![]() ![]() |
I had the same a few months ago and mine was the stalk that does the dip to main. There is a small metal contact that connects either dip or high that had melted, take off the column covers and have a look.
Mine is a TD5 but I believe they are the same set up 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys 1996 130 300TDi chip truck for tree surgery business |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
That reminds me. Must wire in a relay to reduce the current on the switch. Here we go again, doing Land Rover's job for them
![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Sounds silly but check the bulbs as well. I had an odd experience when both dip elements failed together
![]() found that out after I had checked all switches, relays, fuses etc. So it can pay to check the obvious first ![]() |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 ![]() ![]() ![]() |
The main beams work from the stalk on flash (stalk pulled) but not on main beam (stalk pushed) so it can't be the bulbs. Thanks for the reply though, you still enjoying 4 gears that manage themselves? |
Oh Yes... Only today I went for a little wander along a green lane and then just had to go back the same way ![]() I ma also commuting more so traffic jams are not an issue any more. Cheers BM52 |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
See here on this thread. [url] http://www.defender2.net/forum/topic19350....elay[/url]
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2232 ![]() ![]() |
Same happened to me few wks ago . Traced problem to the 3 pin headlight plug ( the one that plugs into the headlight ) the metal clip contacts inside the plastic housing had spread open , crumbled and shorted causing the plastic to melt and no lights . Very poor quality and cheep nasty part .
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 ![]() ![]() ![]() |
Sadly, same could be said for any number of parts in a Defender.... |
UPDATE
Had land rover assist out. Checked fuses, relays, connectors and the main light switch, all seemed to be ok. Technician diagnosed fault in column switch, off to the dealers for repair. I have given them a list of other issues to work through; 1. Leak on fuel tank when full. 2. rusty headlamp rings (dealer pointed out that they are a no cost option). 3. Rusty front bumper (apparently this is standard fit to all defenders). 4. Radio interference when aircon kicks in. 5. Rusty rear crossmember. Now slumming it in a 2013 freelancer with all the toys. |
oh how it all sounds so familiar. Welcome to the defender club. |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Too familiar...
I changed this switch 3 times ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 ![]() ![]() |
Hi guys,
just to confirm that all puma defender are fitted with headlight relays now? they are the R122 relays on the diagram?? THanks Martin |
Martin,
If that were the case, it would have been reported as breaking news all over the forum I think. ![]() Wishful thinking, that would be too much inventive engineering at the end of the current Defender's lifespan. ![]() ![]() Afraid the headlamp relay remains just an after market job, but as you have seen reported in recent threads, there are options on the market, notably in Holland. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Relay above OBD socket is for headlights according to the workshop manual. |
