Home > Puma (Tdci) > Map & Maf sensors |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
Here is the MAP sensor
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated www.td5.org |
27th May 2013 8:38am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20299 |
The MAF is on the air box with a directional arrow on it. (be sure to re-fit the same as you removed it) ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
27th May 2013 8:42am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1308 |
Bit small but from the manual.... Click image to enlarge |
27th May 2013 8:02pm |
07PUMADRIVER Member Since: 08 Apr 2013 Location: north wales Posts: 4 |
Thank you that's great.
28th May 2013 7:38am |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
Are you cleaning them? Can you? I'd like to try think mines an dieselholic William
28th May 2013 4:10pm |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 |
Both sensor can be cleaned by thoroughly spray them with brake cleaner spray products ?
28th May 2013 7:30pm |
Cool I never knew that, thought they were unrepairable items. Cheers that saved me a few quid :p William
28th May 2013 8:53pm |
You can also do the same on your EGR Valve if you've the time and the inclination. If you go through life with your head in the sand....all people will see is an ar5e!!
28th May 2013 9:58pm |
I plan on doing all three when I have the time. Summer holidays from the uni now William
28th May 2013 10:50pm |
