Home > Puma (Tdci) > Map & Maf sensors
07PUMADRIVER
Wales 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Map & Maf sensors
I've read a lot on the forum about these MAP & MAF sensors but can't seem to find photos as to their location as fitted to the 2.4 Puma.
Have had the vehicle about 5 years and recently experienced a power loss Sad when at operating temperature doing about 60mph so thought they might benefit from a clean.
Could someone advise if there are any photos are on the forum or kindly post some.
Thanks in advance.
Post #238893 27th May 2013 8:34am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Here is the MAP sensor
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  www.td5.org
Post #238895 27th May 2013 8:38am
The MAF is on the air box with a directional arrow on it. (be sure to re-fit the same as you removed it) No Guts, No Glory.
Post #238898 27th May 2013 8:42am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Bit small but from the manual....
Post #239059 27th May 2013 8:02pm
07PUMADRIVER
Thank you that's great.
Post #239129 28th May 2013 7:38am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Are you cleaning them? Can you? I'd like to try Smile think mines an dieselholic Rolling with laughter William
Post #239285 28th May 2013 4:10pm
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
Both sensor can be cleaned by thoroughly spray them with brake cleaner spray products ?
Post #239354 28th May 2013 7:30pm
william8
Cool I never knew that, thought they were unrepairable items. Cheers that saved me a few quid :p William
Post #239384 28th May 2013 8:53pm
K9F
You can also do the same on your EGR Valve if you've the time and the inclination. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #239404 28th May 2013 9:58pm
william8
I plan on doing all three when I have the time. Summer holidays from the uni now Wink William
Post #239419 28th May 2013 10:50pm
