![]() | Home > Puma (Tdci) > Map & Maf sensors |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Here is the MAP sensor
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20759 ![]() ![]() |
The MAF is on the air box with a directional arrow on it. (be sure to re-fit the same as you removed it) WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1315 ![]() ![]() ![]() |
Bit small but from the manual.... ![]() Click image to enlarge |
07PUMADRIVER Member Since: 08 Apr 2013 Location: north wales Posts: 4 ![]() ![]() ![]() |
Thank you that's great.
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Are you cleaning them? Can you? I'd like to try
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Both sensor can be cleaned by thoroughly spray them with brake cleaner spray products ?
Cool I never knew that, thought they were unrepairable items. Cheers that saved me a few quid :p William
You can also do the same on your EGR Valve if you've the time and the inclination.
![]() Treat every day as if it is your last....one day you will be right!! |
I plan on doing all three when I have the time. Summer holidays from the uni now
