![]() | Home > Maintenance & Modifications > Water leak... |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
Tonight it is going to rain so I taped up the alpine window. Going sailing for the weekend so I will not be able to test the result until Monday.
However, can someone explain to me exactly how water can run all the way from the alpine window to the driver door. I have only had my Defender for a short time so I am not familiar with how it looks like under the roof lining. And the inside gutter, which you can see looking down the alpine window, has got holes drilled in it so water would come out by the 2nd row of seats. Or am I wrong? By the way, my sailing boat also developed a leak (from the top...) last season and it took quite a while to trace where it came from. I re-sealed a couple of windows and now we will see if it cured the leak. I also have awater leak in my house but I will not go into that (off topic...) Thanks for all advise. /Hans |
I would still be tempted to investigate the washer pipe, even though you may not have used it there may be water still coming out of the pipe. Identify the pipe to the rear by pulling the pipe out of the system, then blow through it to empty out the water(if any) then leave it off for a while and see if you get any fresh leaks
Thanks JWL for your suggestion. I will test it after the test of the alpine window. But if it is the washer pipe how comes that my leak only occurs after rain?
/Hans |
discoed Member Since: 18 Nov 2011 Location: Yorkshire Posts: 20 ![]() ![]() |
![]() http://www.mylandy.com.my/wp-content/uploa...ngress.pdf It's why we like them! ![]() |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
I sealed the gutters using a silicone sealant (and masking tape to keep it tidy); sealed the joint in the roof in the same way and dabbed sealant in some of the welds where I thought I could see hairline cracks.
This lessened the water ingress but what stopped it was polishing the roof. I don't know whether some polish got into a crack or whether the water beading off is what did the trick but no more water for a couple of months now. Hooray! |
Thanks for all ideas. Got back from my sailing weekend tonight. Plenty of rain but no leaks in the boat...
When I took the first corner in the Defender, a large amount of water landed on my knee. So taping up the alpine window did not take care of the leak. Earlier I sealed a crack in the gutter but this did not make any difference. I have also tried to look for other cracks or openings where the water could enter but can not find any. I have ruled out condensation as this problem only occurs when the vehicle has been parked in rain. Also leakage from the washer pipe has been ruled out as I have not been using this for a long time. How can this be so difficult? Any other ideas? Must I remove the roof lining to find the leak? /Hans |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
I think Jamie may have got the right answer....do your tape test on the joint in the roof
Yesterday it was raining again and surprise, no water leak this morning! Could it be that the leak yesterday came from water that was left inside the roof lining prior to me taping the alpine window? Tonight it is going to rain again so I will leave the tape on the alpine window and check tomorrow. If it does not work I will tape up the roof seam as suggested by Jamie and Steve. Thanks!
/Hans |
The rain never materialised last night but has started now. So tomorrow we will see...
/Hans |
After the rain last night I am happy to inform you that there was no leak this morning.
So it seems that the leak started from the alpine window. What sealant compound do use? I use Marine Sikaflex for the boat so I will try this on alpine window as well. And I will put some on the roof seam as well. Thanks for all suggestions. Hans |
A couple of days ago I thought that I stopped the leak by taping up the alpine window. But the water is still flowing from the top of the door by the A-pillow when I take a sharp left turn. And ens up on my knee. The car is LHD so can you gus understand where it commes from? I thought a water would flow to the other side of the vehicle?
I will tape up the roof seem before next rain to see if the leak starts here. Report will follow... /Hans |
Every time when I drove off after a rain at the first sharp corner I got a flood of water over me. It came from the top of the driver door (LHD) close to the A pillar. For a long time I was trying to figure out where it came from. Also studied the water ingress manual. I just could not figure it out.
In the end I bought a bottle Capt. Tolleys Creeping Crack Cure and I put that stuff in every seam and along all seals. And I could not belive it - no more leaks. It has now been water tight for several months and we have had several heavy rains ![]() http://www.captaintolley.com/ Regards, Hans |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
How do you apply this stuff? The leak in my windscreen is starting to annoy me.
Thanks ciao ![]() |
You just squeeze out the liquid around the windscreen seal or any other suspected cracks. The liquid will pentate into any openings and seal it. I applied it around the alpine windows as I suspected these. I still have no idea where the water got in but the problem is gone. ![]() /Hans |
