Home > Maintenance & Modifications > Water leak... |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
I have had this Defender for a month. Its a 110 TD5 2004 LHD.
Water (about 5cl?) comes out at the top of driver door near A-frame. From between the inner roof and the plastic seal (not rubber door seal). It also comes out on the outside above the rubber door seal. It only comes out when I reverse or corner sharply. The leak only occurs when it has been parked over night. Never while driving in rain. I have studied the water ingress manual but fail to understand where the water enters or where it collects. Any ideas? /Hans |
22nd May 2013 9:55pm |
discoed Member Since: 18 Nov 2011 Location: Yorkshire Posts: 20 |
Defenders will leak - it's in their nature. You will be far happier if you just accept it and mop it up. With the construction and design used water leaks are inevitable.
In my old work 110 I had to keep a folder handy to deflect the water from the sunroof from landing on my head when leaving the yard - that was why I had waterproof seat covers! |
22nd May 2013 10:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
Would it not have been better to have waterproof head protection? No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
22nd May 2013 10:12pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Probably leaking from the sunroof or alpine windows. It collects in the inner roof gutter and flows out wetting your knee when braking or sharp cornering. Guess how I know? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
22nd May 2013 10:14pm |
It only happened once a trip - no justification for a waterproof hat
No sun roof fitted and I have checked the inside gutter through the alpine window and it seems to be bone dry. Only dust... Can water follow the inner roof from alpine window all the way to front door?
So far I have ruled out condensation because of the amount of water. /Hans |
22nd May 2013 10:23pm |
Yes |
22nd May 2013 10:24pm |
I will tape up the alpine window seal before next rain to test if this is the problem. Thanks.
/Hans |
22nd May 2013 10:34pm |
This might come in handy: Water Ingress Manual, see Process No. 2.5
Good luck Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
22nd May 2013 10:45pm |
Yes VeeTee, this is about where the water comes out. But I want to know where it goes in as it happens when the vehicle is stationary.
/Hans |
22nd May 2013 11:08pm |
Might be worth a look at whether you have a leak from the feed pipe to the rear wash wipe, yours is a left hand drive and the washer pipe runs (IIRC) in the channel where the roof meets the sides on the near side.
22nd May 2013 11:30pm |
also check,
> top of windscreen, where it meets the roof > top of A pillars - should have sealant |
23rd May 2013 6:01am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5861 |
On mine, I found a gap where the roof drivers corner meets the A pillar. Resealed this and also resealed & replaced the Alpine window seal and applied plenty of sealant.
This caused the leak from standing. However, driving during heavy rain or parking at the wrong angle I still get water in. Looking at the roof there appears to be a bit of play (as in I can move the roof up and down a couple of mm, and I suspect as I am driving into heavy rain, the wind is pushing the roof up a little, opening the gap and allowing water in. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
23rd May 2013 7:20am |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 |
Mine has a leak which drips on my right knee. Thanks for the link I now know where to check and fix. |
23rd May 2013 4:58pm |
