![]() | Home > Maintenance & Modifications > Water leak... |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Thanks Hans, much appreciated
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
Yes, I would apply it around the hinges and probably also around the bolt heads. But if you have found the source for the leak then I am sure there are better ways by removing the hinges and put on some sealing compound like Sikaflex.
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3792 ![]() ![]() ![]() |
Hans, thanks. I was just wondering whether this stuff damages the paint, or can you just wipe off the excess from any painted area which might come into contact with it during its application?
Pickles. |
It will not damage the paint as far as I know and you could wipe off any excess. I used it on the roof which is white and if I look very close I can notice a slight discoloration. I guess this will polish off but I have not tried.
/Hans |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
One of the other forum users suggested - Captain Tolleys creeping crack cure. Its a very fine glue sealant that follows the same path as the water and seals the ingress hole. I used it on the inside of my 110 and it seemed to work well. I also siliconed the holes on the rear rivets above the back door which helped the issue go away totally.
