Home > In Car Electronics > The definitive Defender ICE thread
Page 35 of 71 <123 ... 343536 ... 697071>
barbel jim
custom90steve wrote:
If it still does it try some shielded RCA's. ( No need for £20 one's E-bay shielded RCA's I have been pleased with for around £10
Now that bit of advice I am surprised by Steve.Not saying your wrong but its a bit like using cheepo oil instead of branded, ie you get what you's pays for.Guessing the active sub was working fine until it was recently disturbed. Cheap rca's do have a habit of failing due to cheap materials and production. What you said about electrical interference is true, but these active subs draw minimal current. I would check earth, rca's leads, then routing of the cables in that order. Personally I use Stinger 4000 RCA's . They are half the width of standard, shielded and ultra flexible and reliable. Oh and I paid £30 for 2 Thumbs Up
Post #226590 12th Apr 2013 11:59am
But what length are you requiring? I'm assuming right back to the HU? Due to my HU's separate control unit I only need 1.5M / 2M to avoid having excess cable.
Plus the kitty was a little short after spending so much. Embarassed TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #226592 12th Apr 2013 12:09pm
Another issue is not many out there have 90 degree plugs on which was another issue I found as it suits what I need far better. Yes, you can get 90 degree adaptors but I don't want all that gubbins attached. Laughing
They are also shielded and despite common attitude these particular one's I have had have been brilliant. But yes if you don't need 90 degree plugs or a shorter RCA cable like I do / did then your solution is much better.
**EDIT**
barbel - Forgot to mention. What do you use for your primary power cables? y that I don't mean gauge but brand?....
I used Proflex on mine brilliant stuff and looks nice too. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #226593 12th Apr 2013 12:13pm
barbel jim
There is not a lot of difference in price as the main expense is the plugs on the end. It's just my opinion Steve, and I am just surprised as you know your stuff and like decent kit. An extra tenner is nothing when you'll spend £90 on tweeters. Thumbs Up
Post #226595 12th Apr 2013 12:19pm
barbel jim
**EDIT**
I ended up using Audioleads. When I started originally I was using JL Audio which was bright red, heavy copper core and looked the biz. Unfortunately my supplier ran out and was unable to source anymore . so having OCD I had to rip it out and replace it so it all matches. The Audioleads is supper supple, but a dull red and semi translucent. I preferred the looks of the JL but the Audioleads is so easy to route!! It's all better than using one of those amp wireing kits!
Post #226600 12th Apr 2013 12:31pm
Know what you mean. I'm not a fan of AGU fuse holders either.. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #226602 12th Apr 2013 12:38pm
Anyone been doing much with their Defender lately in the nice weather? Not had a chance to touch mine too much on at the moment to have time. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #229399 21st Apr 2013 4:06pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi, thinking of changing my Alpine sub to a Kenwood KSC-SW11 as it should fit behind my cubby, the Alpine is now too tall for the new auto style cubby and is currently cable tied to the bulkhead bar.
Has anyone any experience of the Kenwood sub or can recommend an active sub that is less the 240mm high.
Thanks BM52
Post #236887 19th May 2013 5:30pm
Shall have a look a little later for you. Would you consider Kicker too? Would be much more powerful than the Kenwood and a nice rectangular shape. (Not sure on size though)
Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #236934 19th May 2013 6:31pm
bm52
I am no ICE expert as long as it has a good rounded sound and decent bass. I am very eclectic with my music, from classical, through jazz, rock, prog rock, some pop [ Shocked ] etc etc
The Alpine has worked well for me, it's just the size.
Thanks BM52
Post #236944 19th May 2013 6:43pm
bm52 wrote:
I am no ICE expert as long as it has a good rounded sound and decent bass. I am very eclectic with my music.
So can I be also. Laughing I've found my Kicker system absolutely brilliant although not the hideaway the same brand and for subs and amps I personally would go for Kicker over Kenwood as the power is far higher for most of it all be it perhaps a little more expensive. Everything else Kenwood though.
The Kicker hideaway looks like this:
Suits the Defender well IMO and is roughly twice the power of the Kenwood SW so value for money is good too. Plenty of bang for your buck so to speak.
Specific details here: http://www.kicker.com/hideaway Dimensions are (CM) 35.2 x 9.94 x 23.8
Available here: Kicker Hideaway from ICM E-bay store
I would recommend the above seller as I got my kit from him last year and was very good to deal with. Even gave some discount up on asking nicely & getting in contact.
Height wise it is more or less the height you mentioned but no larger at all so I hope that is okay.
Steve
:thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #236991 19th May 2013 7:44pm
bm52
that does look good, i'll have to get my tape measure out and see if it will fit, looks tight but do-able Thumbs Up
it has to fit below the hinge join at the rear of the cubby.
thanks BM52
Post #237024 19th May 2013 8:42pm
I see what you mean. If you find it a touch tight just try a neat backing board and position it slightly lower to make up the difference. I assume the cubby bottom isn't right against the floor?... TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #237030 19th May 2013 8:48pm
bm52
it's the auto cubby, see below, sorry for bad pics
 BM52
Post #237040 19th May 2013 9:08pm
Should look neat on the back of there if all goes well. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #237048 19th May 2013 9:49pm
