Home > Td5 > Defender 90 TD5 CSW 1998 (S) |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
Congratulations
ECU is under drivers seat |
13th Apr 2013 8:17pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Ah.....that's why I couldn't find it.......odd that most googles said passenger seat, is it there on some models then ?
13th Apr 2013 8:27pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Might be under passengers seat on a left hand drive 2005 Td5 90 XS
Steve |
13th Apr 2013 8:32pm |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 |
Congratulations on your new purchase
The ecu depends on the market I think, it doesn't swap sides when the steering wheel does. Mark S CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
13th Apr 2013 8:36pm |
The ecu does,nt change sides on a LHD the passenger however does. 2005 Td5 90 XS
Steve |
13th Apr 2013 8:40pm |
Ok I will look under the drivers seat tomorrow morning.......what about the remapping? Would this be possible if an original ecu? I need to find out why it faulters above 2500 rpm
JD |
13th Apr 2013 8:42pm |
Plenty of threads on here regarding Td5 missfire etc,when you do find the ecu under the right hand seat disconnect the red plug and check for oil contamination in there.This is very common and is easily sorted with a new injector wiring harness.Let us know how you get on and welcome to the joys of Defender ownership. 2005 Td5 90 XS
Steve |
13th Apr 2013 8:48pm |
Hi Lou
Yeah I have read lots today about the wiring harness and oil contamination.........that why I went looking for the dreaded red plug today.......and only found a battery LOL........... |
13th Apr 2013 8:52pm |
TD5_90 Member Since: 02 Apr 2011 Location: Perthshire Posts: 89 |
Hi
As well as oil in ecu, performance issue could be due to your MAF sensor failing or the wastegate actuator arm sticking. Yes you can get a remap on the older ecu - I have a 99my and got it done Enjoy the Defender! |
14th Apr 2013 10:43am |
Well...today I found the ECU......no oil in red plug that i can see....also i checked movement on the wastegate actuator arm and it seems free.........HMMMM
14th Apr 2013 6:18pm |
Try disconnecting the plug from the maf sensor and go for a drive if it improves significantly that is probably your problem. 2005 Td5 90 XS
Steve |
14th Apr 2013 6:24pm |
Hi Lou
Yep just reading about the MAF sensor......thats next to try Many Thanks JD |
14th Apr 2013 7:01pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
If you are down near Taunton at any time I have a known good MAF sensor I can fit for you to try
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
14th Apr 2013 7:31pm |
Thats very kind of you indeed Bob I may need to look at it prior to then if i can find the darn thing
15th Apr 2013 12:51pm |
