Home > Td5 > Defender 90 TD5 CSW 1998 (S)
johnnyd
Hi, I have my first ever Land Rover Smile
Can i ask a few basic questions first please.....What spec is my Landy likely to be ? Also I have been looking for my ECU, most forums said it was under the passenger seat, i removed the passenger seat today and found the battery
Also can my ECU be remapped being Dec 1998? it seems to be very sluggish above about 2500RPM in any gear, does that point to anything obvious ?
It seems in very good condition body wise
Many thanks
Post #226957 13th Apr 2013 7:14pm
Congratulations Thumbs Up
ECU is under drivers seat
Post #226958 13th Apr 2013 7:17pm
johnnyd
Ah.....that's why I couldn't find it.......odd that most googles said passenger seat, is it there on some models then ?
Post #226964 13th Apr 2013 7:27pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Might be under passengers seat on a left hand drive Whistle 2005 Td5 90 XS
Steve
Post #226965 13th Apr 2013 7:32pm
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
Congratulations on your new purchase Smile
The ecu depends on the market I think, it doesn't swap sides when the steering wheel does. Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #226966 13th Apr 2013 7:36pm
Lou Sparts
The ecu does,nt change sides on a LHD the passenger however does. 2005 Td5 90 XS
Steve
Post #226971 13th Apr 2013 7:40pm
johnnyd
Ok I will look under the drivers seat tomorrow morning.......what about the remapping? Would this be possible if an original ecu? I need to find out why it faulters above 2500 rpm Sad
JD
Post #226973 13th Apr 2013 7:42pm
Lou Sparts
Plenty of threads on here regarding Td5 missfire etc,when you do find the ecu under the right hand seat disconnect the red plug and check for oil contamination in there.This is very common and is easily sorted with a new injector wiring harness.Let us know how you get on and welcome to the joys of Defender ownership. 2005 Td5 90 XS
Steve
Post #226978 13th Apr 2013 7:48pm
johnnyd
Hi Lou
Yeah I have read lots today about the wiring harness and oil contamination.........that why I went looking for the dreaded red plug today.......and only found a battery LOL...........
Post #226982 13th Apr 2013 7:52pm
TD5_90
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
Hi
As well as oil in ecu, performance issue could be due to your MAF sensor failing or the wastegate actuator arm sticking.
Yes you can get a remap on the older ecu - I have a 99my and got it done Thumbs Up
Enjoy the Defender!
Post #227092 14th Apr 2013 9:43am
johnnyd
Well...today I found the ECU......no oil in red plug that i can see....also i checked movement on the wastegate actuator arm and it seems free.........HMMMM
Post #227201 14th Apr 2013 5:18pm
Lou Sparts
Try disconnecting the plug from the maf sensor and go for a drive if it improves significantly that is probably your problem. 2005 Td5 90 XS
Steve
Post #227206 14th Apr 2013 5:24pm
johnnyd
Hi Lou
Yep just reading about the MAF sensor......thats next to try Wink
Many Thanks
JD
Post #227235 14th Apr 2013 6:01pm
bob neville
If you are down near Taunton at any time I have a known good MAF sensor I can fit for you to try Thumbs Up
2013 Defender 90 CSW - sold
Post #227255 14th Apr 2013 6:31pm
johnnyd
Thats very kind of you indeed Bob Smile I may need to look at it prior to then if i can find the darn thing Smile
Post #227429 15th Apr 2013 11:51am
