![]() | Home > In Car Electronics > The definitive Defender ICE thread |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
31A draw on that Amp too so a 35A fuse would be ideal or if difficult to find then a 40A. Personally I'e gone for AFS fuse and holder not the cheaper AGU. Although will still work just the same but there have been issues with AGU fuse holders.
Barbel Jim - What if he doesn't want Alpine. ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
Then he'll have to buy another ! ![]() ![]() ![]() ![]() ![]() |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 ![]() ![]() ![]() |
you sayin my stuff ain't decent ![]() ![]() ![]() just kidding, I might still need your sub, I'll get back to you ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Steve & Jim, thanks for your input...
this is where the speakers and sub will be living, the top box... ![]() Click image to enlarge the box is mainly used for jump cables, straps'n'stuff, it sits on rails so I can have the space in front or back like such.. ![]() Click image to enlarge I can fit the speaker's facing the cab or the rear but the sub will be facing downwards, unless I have to go smaller (Like an alpine ![]() I was hoping to wire the sub and 6x9's like this diagram showing the 3 channel set up ![]() Click image to enlarge but looks like I have to think again, what do you guys think cheers Mike :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Not at all, just a bit of love towards Steve. ![]() ![]() |
Thanks Jim, I also have a little 100w amp I was thinking of connecting for the fronts, still toying with that idea, most of this stuff I have obtained very cheaply or inherited from guys at work who have upgraded (apart from the amp) and it was all collecting dust in my workshop so I thought I'd have a dabble as the sound in my 90 is poor to say the least. I won't be having the sub cranked up to give me extra boom boom power going uphill
![]() ![]() ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! Last edited by taffrican on 11th Apr 2013 4:31pm. Edited 1 time in total |
![]() ![]() ![]() I can't see powering the 6x9's and Sub on that one Amp will work the 6X9's would probably be okay but the Sub very underpowered. I would go for a Mono Amp for the Sub and a 2 channel for the 6X9's. Sound reasonable to you Barbel? ![]() β½οΈπ’οΈβοΈπ§°πͺ |
So do you think I should bin the amp I've got? or bin the amp? or start from scratch? or could I use the amp to drive the front speakers & 6x9's and get Barbel's sub, which I believe will only need an input from my head unit & power? Optimists say the glass is half full..
Gut instinct I would agree with you Steve, But by Wireing it up and seeing what it sounds like will give a true answer. Mike Understand where your coming from and in theory it could work. You will need to separate the sub and 6x9's in that box. Ie separate compartments otherwise back pressure will cause distortion. ![]() ![]() |
Can't type that fast ![]() Just to clarify Mike, my little active Alpine sub is sold. What I do have is a mono block 300 rms amp that will power your sub ![]() ![]() ![]() |
Jim, I am going to build mdf boxes inside the top box, a) for the reasons you stated b) to protect the speakers so I can still use it for storage, I don't want a box that big just dedicated to speakers
![]() I'm thinking of just wiring it all together on the workbench and see what it sounds like ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
how much are you looking for the mono amp? ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Sounds Like a plan
![]() ![]() ![]() Try that first and see what you think, If you want more then My mono amp will be £50 +postage, but try what you have first, see what you think ![]() Personally the little active subs are good, but can't replicate a properly set up sub and amp. They just cannot move enough air. With mine it was drowned by the Amped 6x9s thats why I now have a chavy Sub box ![]() ![]() |
I think I'll try that jim, I've was just a little confused about peak power and rms, I was mistaken thinking 350w rms sub would've been ok on a 600w amp
![]() ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! Last edited by taffrican on 11th Apr 2013 8:06pm. Edited 1 time in total |
