Home > Puma (Tdci) > High Revs for ~ 2 secs+ when changing gear foot off throttle |
This thread perhaps...... It seems that all/most 2.2s are like this. A remap would undoubtedly cure this trait!
http://www.defender2.net/forum/topic18451.html?highlight=revs If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Mar 2013 4:25pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17351 |
Could be the clutch pedal switch not working, but I seem to recall someone posting that this is normal on a 2.2.
If you disconnect the clutch switch and it makes no difference you've found your culprit. |
28th Mar 2013 4:29pm |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 460 |
Thanks K9 and Blackwolf - what on earth do we need a switch on our clutch for?
28th Mar 2013 5:01pm |
Well, I suppose to stop the engine management system from doing what yours is doing!
Seriously though I do agree with you. I often reminisce about the old days when just about anything could be fixed with a minimal toolkit (and no computer!) at the roadside but then I recall how much was spent doing this. Modern cars may be absurdly complex - ours less than most - but in general they are so much more reliable. |
28th Mar 2013 6:36pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Seems normal, as I said in another thread..
Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
28th Mar 2013 10:07pm |
Staftly Member Since: 06 Jul 2012 Location: Lancashire Posts: 55 |
Hi John
Have exactly the same issue with my 1y/o utility XS. Thinking about a remap by BAS to cure this and other issues. If this clutch pedal switch is the problem, it may change my mind, and save me a few quid to boot. Can anyone tell me where I can find, and detatch, this switch? Thanks. Staftly |
29th Mar 2013 1:27am |
hi Staftly,
If you have a remap, please let me know how it goes. I guess my only concern with that would be the possible effect on the warranty. Thanks, John. |
29th Mar 2013 5:06pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
I had this prob when I brought my 08 2.4. The owner had not used it for a month or two as he did not want it to get dirty while trying to sell it.
I had it plugged up & no faults found. After a week or 2 of use it cleared & alls been fine since Maybe yours just needs a good run to get bedded in?? You cant get a remap for 2.2 yet. Unless its been cracked yet Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
29th Mar 2013 7:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20299 |
Mine was like that originally as it had so very little use and to boot only 12k on the clock as well. Very "sticky" gear changes and very little smoothness but went with use. A service can help no end too.. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
29th Mar 2013 7:48pm |
Plodster Member Since: 24 Mar 2013 Location: UK Posts: 22 |
I've done a little under 700 miles in my 2.2 and must say the rev holding function is a little annoying but most acute in low box. I've been inclined to wait a week or so to see how it settles as its very annoying when it's trying to guess your next rev range. Hmmmm, thats not mud....
Current: Defender 110 HD Utility (Special Vehicles) Freelander 2 HSE BMW E23 735i Ex: 2013 Defender 90 2.2 1998 Discovery 300TDi 1972 Series II 2.25 1980 Series III 2.25 |
29th Mar 2013 8:48pm |
5wh Member Since: 01 Jan 2011 Location: Lancashire Posts: 37 |
I had this with my 2.4 a few weeks ago.bloody annoying.in the end I traced it to a blown brake light fuse,replaced the fuse and all is well again now. 2009 SVX 90 Station Wagon
29th Mar 2013 10:56pm |
Hi 5wh. Brake light fuse? that's a weird connection, but there again, knowing how some cars behave you never know. I have checked my brake lights though and they do work OK so therefore I assume their fuse must also be OK, but I'll keep this one in the memory bank just in case. Thanks.
30th Mar 2013 10:17am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
How much higher than the next gear revs does it go, it should drop to the next gear revs, if you wait it should drop all the way. I find it makes for a very smooth up change as the transmission revs are matched with the engine revs as you let the clutch back in, I bet it saves alot of clutch wear as well Original Member Pie n Pea Club.
110 HCPU Tipper |
30th Mar 2013 10:24am |
Hi Willy, So you think that once you get used to it, this feature can actually be a positive thing?
30th Mar 2013 10:29am |
