Home > Puma (Tdci) > DIY - Oil Catch Tank |
Copying your idea:
Bit more expensive than yours but the 25mm connectors may fit the existing hoses. Yes - I am lazy Judging by all the slimy oil in the pipework, this mod might be kinder to the MAF :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
24th Feb 2013 1:07pm |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 |
Great useful mod, thanks for sharing MD5 I'll install on mine, but need to solve what to do with heater of this pipe... Puma 110
27th Feb 2013 4:15pm |
Mine was too big so sent it back
Ordered another from UK (cheaper too) which should be better: I'm going to get some 14mm (internal) tubing with a 3mm wall just to thicken the connections for the 20mm (internal) oil pipe. Fingers crossed... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Feb 2013 4:39pm |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 |
The above is the same as mine. You can cut two slice of the blue transparent rubber hose and put over the inlet and outlet to enlarge the diameter and allow the stock hose to be fitted.
27th Feb 2013 4:47pm |
IMO outlets should be as close to stock pipe as possible i.e. as big as possible - to not increase resistance in pipe for gases. Puma 110
27th Feb 2013 4:58pm |
Funny how I ended up with the same as you Dennis - that's why I went for the first can (connectors were 25mm) but it was just too large Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Feb 2013 5:31pm |
Just a few photos of my "I can't weld for toffee" version. The tap size is M20 and the black connectors are 18/20 mm:
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Matt Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
19th Mar 2013 8:06am |
Nice job, look good.
To add a final touch, we need to fit a kind of "sponge" on the bottom of the filter to allow better oil retention. Any idea about what to fit inside ? |
19th Mar 2013 9:09am |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 151 |
Pan scourer's
19th Mar 2013 11:15am |
Last bits arrived. I decided to use an angled connector on the can as it would allow the hose to go directly into the intake. I'm also holding the can on with a QuickFist as it dampens vibration and looks a bit more OEM. Has the unexpected advantage of "cuddling" the sensor in the same position as on the metal bracket
Click image to enlarge Click image to enlarge Happy :mrgreen: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
30th Mar 2013 4:09pm |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 |
looks great where did you get the mounting rubber bracket from cheers tim Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Cess the Taswegian |
16th Jun 2013 9:44am |
They are quick fist clamps. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
16th Jun 2013 9:49am |
Wot he said Tell someone you love them today because life is short.
16th Jun 2013 9:55am |
http://www.ebay.de/itm/Quickfist-Befestigu...562b83d1f9
but check the size... p.s. I've trimmed mine a bit since the above photos to make it easier to get the tank off. p.p.s. Before you fit the tank, make very sure the bottom is screwed on tight Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
16th Jun 2013 10:00am |
