Home > Puma (Tdci) > DIY - Oil Catch Tank
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
I fit a oil catch can in the engine vane to help separate oil and sludge from the gas flow coming from the engine breathing system.
This mod can help in keeping clean the turbo, intercooler and related hose.
I bought a cheap alluminium Universal Oil catch tank from eBay like this one:
Then I drilled the inlets to fit a larger alluminium pipe where to plug the stock black rubber hose. The new inlets was welded to the head of the catch can.
A separator was also welded inside the head of the catch can to help the separation between oil/sludge and gas flow.
The catch can was then fixed with two quick release hose clamp to a factory installed bracket on the wing, near the turbo heat shield.
The stock hose p/n LLN500030 connect the engine head to the catch can inlet. The connection between the catch can outlet and the duct-air is made by using a second LLN500030 hose (price 4.5 euro) + a 90 degree manifold.
About the effectiveness, the next 2 pics show some oil drops and sludge collected after a very short 300km trip. I will recheck after a few thousand km.
The filter can be further improved by adding some kind of steel wool on the inside, just be sure it does not release harmful debris that can be flowed outside the filter and hit the turbo fins.
Any feedback appreciated, sorry for my bad English!
Post #213793 24th Feb 2013 12:53pm
ZeDefender
Copying your idea:
Bit more expensive than yours but the 25mm connectors may fit the existing hoses. Yes - I am lazy Laughing
Judging by all the slimy oil in the pipework, this mod might be kinder to the MAF :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #213797 24th Feb 2013 1:07pm
Denis
Russia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
Great useful mod, thanks for sharing MD5 Thumbs Up I'll install on mine, but need to solve what to do with heater of this pipe... Puma 110
Post #214755 27th Feb 2013 4:15pm
ZeDefender
Mine was too big so sent it back Rolling Eyes
Ordered another from UK (cheaper too) which should be better:
I'm going to get some 14mm (internal) tubing with a 3mm wall just to thicken the connections for the 20mm (internal) oil pipe.
Fingers crossed...
Post #214765 27th Feb 2013 4:39pm
MD5
The above is the same as mine. You can cut two slice of the blue transparent rubber hose and put over the inlet and outlet to enlarge the diameter and allow the stock hose to be fitted.
Post #214771 27th Feb 2013 4:47pm
Denis
IMO outlets should be as close to stock pipe as possible i.e. as big as possible - to not increase resistance in pipe for gases. Puma 110
Post #214776 27th Feb 2013 4:58pm
ZeDefender
Funny how I ended up with the same as you Bow down
Dennis - that's why I went for the first can (connectors were 25mm) but it was just too large Big Cry Tell someone you love them today because life is short.
Post #214786 27th Feb 2013 5:31pm
ZeDefender
Just a few photos of my "I can't weld for toffee" version. The tap size is M20 and the black connectors are 18/20 mm:
Matt
Post #220381 19th Mar 2013 8:06am
MD5
Nice job, look good.
To add a final touch, we need to fit a kind of "sponge" on the bottom of the filter to allow better oil retention.
Any idea about what to fit inside ?
Post #220388 19th Mar 2013 9:09am
Les Brock
Pan scourer's Mr. Green
Post #220405 19th Mar 2013 11:15am
ZeDefender
Last bits arrived. I decided to use an angled connector on the can as it would allow the hose to go directly into the intake. I'm also holding the can on with a QuickFist as it dampens vibration and looks a bit more OEM. Has the unexpected advantage of "cuddling" the sensor in the same position as on the metal bracket Thumbs Up
Happy :mrgreen:
Post #223462 30th Mar 2013 4:09pm
Tim seymour
Australia
H appy Mr. Green
looks great where did you get the mounting rubber bracket from cheers tim
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cess the Taswegian
Post #244006 16th Jun 2013 9:44am
VeeTee
Netherlands
They are quick fist clamps. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #244008 16th Jun 2013 9:49am
ZeDefender
Wot he said Thumbs Up Tell someone you love them today because life is short.
Post #244009 16th Jun 2013 9:55am
ZeDefender
http://www.ebay.de/itm/Quickfist-Befestigu...562b83d1f9
but check the size...
p.s. I've trimmed mine a bit since the above photos to make it easier to get the tank off.
p.p.s. Before you fit the tank, make very sure the bottom is screwed on tight Whistle Tell someone you love them today because life is short.
Post #244010 16th Jun 2013 10:00am
