![]() | Home > Maintenance & Modifications > rear door central locking failure('06' Defender) |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Dont suppose you took any piccies of your repair?
stoker 2005 TD5 90 Hard Top Beer 'n Sex 'n Chips 'n Gravy ![]() |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 ![]() ![]() ![]() |
Hi “Stoker”.
Did think of images, but never took any. Basically its push the rotating arm back into position and put a short/ fat self tapper through it to fix into position.. If you PM me with your email I will set up the offending bit and take a some images and post then to you |
Thanks EWS, I get the gist of it. I'm just preparing myself for when it is my turn
![]() How's things in Thornbury since the murder? 2005 TD5 90 Hard Top Beer 'n Sex 'n Chips 'n Gravy ![]() |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 ![]() ![]() ![]() |
Hi EWS
Did you take those photos you mention ? I seem to have the same problem which developed a couple of days ago - so would be grateful if you could send those photos to help me diagnose the problem Cheers Gavin |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
For three years my rear door would lock but not unlock on the central locking so one day after washing all the gunk out of the front door locks to stop the dreaded bounce back (thread on here somewhere) and curing that problem i thought i might as well do the same to the rear door lock.So i sprayed WD40 in the key hole and into the lock from the door latch area and through the lock button on the inside and hey presto works every time now.Nice easy fix. 2005 Td5 90 XS
Steve |
Thanks Lou - got to be worth a try
Gavin |
Well what do you know Lou - it worked. Many thanks.
Gavin |
