Home > Maintenance & Modifications > rear door central locking failure('06' Defender)
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Hi all.
Had a problem with the central locking on the rear door of our ’06 ‘ Defender. It would lock but not unlock, them it failed to lock at all, but worked on the key okay.
What I discovered, after removing the lining/cover, was the 3 pointed plastic arm,( held in place with two legs in a square hole)which connects the central locking unit rod, via this item to the door lock via a rod, which is secured to the door panel with a integral spreader, to lock in position in the door panel, has worked it way out of the internal door panel.
After pushing the plastic piece back into position , worked the locking mechanism a few times, it gradually worked it way out from the panel till it fell free from the panel. It appears to be only a friction fit, and the two lugs had worn enough to allow it work its way out.
Interestingly it had a hole through the centre, should it have had a screw fitted to spread the legs/lugs, to fix in position ?. No sign of thread cutting to show a screw had been fitted. Thinking about other fixing on the truck which are plastic and use a screw the fix in position , I screwed in a short but fat self tapper in and that seems to have fixed the problem, by spreading the lugs and gripping the panel, no further problems
Post #127293 27th Feb 2012 11:52pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Dont suppose you took any piccies of your repair?
stoker 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #127324 28th Feb 2012 7:40am
EWS
Hi “Stoker”.
Did think of images, but never took any. Basically its push the rotating arm back into position and put a short/ fat self tapper through it to fix into position..
If you PM me with your email I will set up the offending bit and take a some images and post then to you
Post #127547 28th Feb 2012 9:57pm
chiefstoker
Thanks EWS, I get the gist of it. I'm just preparing myself for when it is my turn Laughing
How's things in Thornbury since the murder? 2005 TD5 90 Hard Top
Post #127789 29th Feb 2012 8:11pm
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Hi EWS
Did you take those photos you mention ?
I seem to have the same problem which developed a couple of days ago - so would be grateful if you could send those photos to help me diagnose the problem
Gavin
Post #211151 14th Feb 2013 11:13am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
For three years my rear door would lock but not unlock on the central locking so one day after washing all the gunk out of the front door locks to stop the dreaded bounce back (thread on here somewhere) and curing that problem i thought i might as well do the same to the rear door lock.So i sprayed WD40 in the key hole and into the lock from the door latch area and through the lock button on the inside and hey presto works every time now.Nice easy fix. 2005 Td5 90 XS
Steve
Post #211183 14th Feb 2013 1:13pm
gavinpm
Thanks Lou - got to be worth a try
Gavin
Post #211184 14th Feb 2013 1:20pm
gavinpm
Well what do you know Lou - it worked. Many thanks.
Gavin
Post #211249 14th Feb 2013 8:42pm
