![]() | Home > Puma (Tdci) > Heated Rear Window |
Take it to the dealer and get it replaced, they should all work
It's a pity but quite normal
![]() My 07 had a new window because of the top three bars were nackered and I have just had a new one in the 09 about three weeks ago ![]() |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
There's a thread on this somewhere. It is quite common but is also a fault - get the dealer to change it.
My front screen had a strip right in front of my face that wasn't working. The dealer "did some tests" and couldn't demonstrate the issue (bear in mind it was minus 3 outside - breathing over the windscreen would have done it ![]() Only way to prove it then was to take these photos to show them that I hadn't made it up. ![]() ![]() + New Defender 110 First Edition |
The problem for the rear heated glass is the 3rd stop tail rubber.
probably it release rubber solvent that "eat" the heated element Dealer changed me the rear windows two times. Now I cutted (below) the rubber and make same sockets (where are 90° tracks curves) for avoid contacts from the heating tracks and the rubber. Now the problem seems solved... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
it's the high level stop light the cover this rubs on the element and cuts through it,when you have had it replaced, cover the elements with insulating tape to stop it happening again 2.4 90 XS
holdingpoint Member Since: 18 Aug 2009 Location: Como Italy Posts: 35 ![]() ![]() ![]() |
Hi all!
Finally I discovered someone that have the same my problem, it's the third rear window that they have changed me in Land Rover without solve the problem. @GROCKLE Is possible for you to post a pictures showing the way to follow to fix the problem, I don't really understood readin. If is possible I will really appreciate, thanks in advance. |
remove the high level brake light cover,look for rubbing marks on the heating elements,if you can see were the heater wires are broken(worn through)you need a heated window repair kit,you mask off either side of the 'break'with the masking tape supplied in the kit,then with the solution in the bottle(looks like clear nail varnish)paint on over the break to all damaged areas,leave to dry, remove the masking tape,then cover the break areas with insulation tape to stop it happening again. I hope you can understand. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
Ok I understand
Holding, devi togliere lo stop posteriore e vedrai dove la gomma tocca i filamenti. La gomma rilascia, probabilmente, dei solventi, che letteralmente mangiano le piste. io ho scavato la gomma con il drummel in modo che la gomma non sia in contatto con le piste e, fino ad ora, il mio III vetro non crea più problemi.... avevo pensato anch'io al nastro ma non so come si comporti la colla con la lega delle piste..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Grande dgartel! grazie
![]() Ma tu come gomma intendi solo la guarnizione oppure anche quella specie di gomma parte integrante del vetro, quella intorno allo stop (come una grechetta a pallini)? |
Quella "trapezoidale", sviti le due vitine del coperchio, sotto troverai 2 bulloncini M8.
prima togli i due faston dello stop (senza sforzare troppo sul vetro, aiutati con un cacciavite), poi svita i due bulloncini ed estrai tutto.... se lo smonti è semplice, è più difficile da scrivere che fare.... la "gomma" incriminata è il n° 5 i "6" rimangono incollati al vetro....... ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Heated windows?
![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
sorry Mates,
I explained to my compatriot that is the central stop lamp rubber (5) (in my case) that probably, release solvent. this solvent had "vanished" the heater elements. I cut and modified the rubber. Now the heater elements do not "touch" the rubber and after 3 rear screen this one " continue" to work fine Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Thanks again for the complete explanation!
