Home > Puma (Tdci) > Heated Rear Window
foiloman
Heated Rear Window
The top two bars/elements on the rear window heater do not warm up.
Is this normal as the top part of the window remains frozen even though there seem to be heating elements below the frost?
08 Defender 110 XS.
Cheers... 2.4 110 XS
Post #20617 23rd Dec 2009 5:06pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Take it to the dealer and get it replaced, they should all work Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #20618 23rd Dec 2009 5:21pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
It's a pity but quite normal Rolling Eyes
My 07 had a new window because of the top three bars were nackered and I have just had a new one in the 09 about three weeks ago Rolling Eyes
Post #20619 23rd Dec 2009 6:06pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
There's a thread on this somewhere. It is quite common but is also a fault - get the dealer to change it.
My front screen had a strip right in front of my face that wasn't working. The dealer "did some tests" and couldn't demonstrate the issue (bear in mind it was minus 3 outside - breathing over the windscreen would have done it Banging Head)
Only way to prove it then was to take these photos to show them that I hadn't made it up.
 One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #20623 23rd Dec 2009 7:39pm
dgardel
Italy
The problem for the rear heated glass is the 3rd stop tail rubber.
probably it release rubber solvent that "eat" the heated element
Dealer changed me the rear windows two times.
Now I cutted (below) the rubber and make same sockets (where are 90° tracks curves) for avoid contacts from the heating tracks and the rubber.
Now the problem seems solved... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #20640 24th Dec 2009 1:26am
Grockle
it's the high level stop light the cover this rubs on the element and cuts through it,when you have had it replaced, cover the elements with insulating tape to stop it happening again 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #20641 24th Dec 2009 7:35am
holdingpoint
Italy 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Hi all!
Finally I discovered someone that have the same my problem, it's the third rear window that
they have changed me in Land Rover without solve the problem.
@GROCKLE Is possible for you to post a pictures showing the way to follow to fix the problem, I don't really understood readin. If is possible I will really appreciate, thanks in advance.
Post #20963 30th Dec 2009 9:53pm
Grockle
holdingpoint wrote:
Hi all!
remove the high level brake light cover,look for rubbing marks on the heating elements,if you can see were the heater wires are broken(worn through)you need a heated window repair kit,you mask off either side of the 'break'with the masking tape supplied in the kit,then with the solution in the bottle(looks like clear nail varnish)paint on over the break to all damaged areas,leave to dry, remove the masking tape,then cover the break areas with insulation tape to stop it happening again.
I hope you can understand. 2.4 90 XS
Post #20972 31st Dec 2009 8:48am
holdingpoint
Ok I understand Thumbs Up thank you
Post #20979 31st Dec 2009 11:54am
dgardel
Italy
holdingpoint wrote:
Hi all!
Holding,
devi togliere lo stop posteriore e vedrai dove la gomma tocca i filamenti.
La gomma rilascia, probabilmente, dei solventi, che letteralmente mangiano le piste.
io ho scavato la gomma con il drummel in modo che la gomma non sia in contatto con le piste e, fino ad ora, il mio III vetro non crea più problemi....
avevo pensato anch'io al nastro ma non so come si comporti la colla con la lega delle piste..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #20981 31st Dec 2009 12:56pm
holdingpoint
Grande dgartel! grazie Thumbs Up
Ma tu come gomma intendi solo la guarnizione oppure anche quella specie di gomma parte integrante del vetro, quella intorno allo stop (come una grechetta a pallini)?
Post #20982 31st Dec 2009 2:24pm
dgardel
Italy
Quella "trapezoidale", sviti le due vitine del coperchio, sotto troverai 2 bulloncini M8.
prima togli i due faston dello stop (senza sforzare troppo sul vetro, aiutati con un cacciavite), poi svita i due bulloncini ed estrai tutto....
se lo smonti è semplice, è più difficile da scrivere che fare....
la "gomma" incriminata è il n° 5
i "6" rimangono incollati al vetro.......
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #20999 31st Dec 2009 7:44pm
NoDo$h
Heated windows? Confused
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #21008 31st Dec 2009 8:49pm
dgardel
Italy
sorry Mates,
I explained to my compatriot that is the central stop lamp rubber (5) (in my case) that probably, release solvent.
this solvent had "vanished" the heater elements.
I cut and modified the rubber.
Now the heater elements do not "touch" the rubber
and after 3 rear screen this one " continue" to work fine Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21010 31st Dec 2009 9:12pm
holdingpoint
Thanks again for the complete explanation!
Post #21082 2nd Jan 2010 11:53am
