Home > My Defender > My TD5 90 |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 663 |
It's looking good and looking at pics thy seem to have done a god job.
Cheers Steve |
25th Jan 2013 10:08pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Green and White- man with taste right there CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
25th Jan 2013 10:24pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
There's just something special about a classic looking working standard defender. Dynamated all mine and well worth it. Just more refined. Mud pannels another big plus. Give it a factory feel OEM finish. I also cut and stuck some rubber matting on the bulk head/side of the tub. Again just finishes it , and also helps so much with sound absorption. Just to give you an idea -
Click image to enlarge |
26th Jan 2013 1:03pm |
238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233 |
That looks well ^^, like the rubber matting that's the look I'm after inside
26th Jan 2013 10:22pm |
Today didn't really go to plan as the painter didn't turn up to finish my roof because of a little snow fall he needs to get a defender
Anyway I carried on assembly and decided to put the roof back on even though its not finished so I could take it home to work on, the painters back on Tuesday so it's going back then for the roof painting and buff The hardest job I've done on it was defiantly fitting the glass back in the rear door.... Need proper tools next time! Few more pics.... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I mocked up the front a bar, still not decided wether to fit it yet (shovels not included ) Click image to enlarge Last edited by 238kirk on 10th Mar 2013 7:25pm. Edited 1 time in total |
26th Jan 2013 10:37pm |
Click image to enlarge It's easy to source I combined it with 6mm insulation foam. I did buy the exmoor trim matting for floor and sides, but wouldn't recommend that. Firstly, its expensive and secondly I had to trim floor mat as it wasn't cut to right dimensions. Cheers Steve Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
26th Jan 2013 10:39pm |
that looks really good that matting exactly what we are after for the back of the xtech CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
26th Jan 2013 10:42pm |
Burn it and then nobody can fit it! |
26th Jan 2013 10:43pm |
26th Jan 2013 10:51pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
How did you stick that matting on? Thanks. Pete. |
26th Jan 2013 10:57pm |
Sorry to hijack your thread Kirk
Sourced the matting from ebayhttp://www.ebay.co.uk/itm/330748435832...1439.l2649 Brought a 3m length for the same postage, and arrived within 48 hrs. Had already dynamatted all the interior so stuck the rubber to that. It goes behind the bulkhead bar and under the mud sides. Made cardboard templates to shape ends, the stuck in with a good spray adhesive, heat gun and patience a plenty. once fitted I then used sika flex to join in the corners, hopefully making a waterproof tub. |
27th Jan 2013 9:15am |
Gave her a little clean and got some up to date pictures
Befere and after pics Click image to enlarge Click image to enlarge |
1st Feb 2013 1:30pm |
Looks sweet - should think your well chuffed
1st Feb 2013 2:56pm |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 |
What a difference.
1st Feb 2013 4:00pm |
