Home > In Car Electronics > The definitive Defender ICE thread |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
I thought it was big previously the boxes I made sat on top of the wheel arches tucked in the corners either side of the door. Quick calcs mean an internal measurement 10x10.5 x5 inches will give me just over .51 cu/ft. Means they will sit forward about 7 inches on the wheel arches ??? Not sure about that ?????
On your other note, I don't know is the answer ?? Seemed pretty friendly on the phone. Give them a ring and ask, they have a sales team/department. |
16th Jan 2013 5:50pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
I shall have to give that a try as they have some good brands! AFAIK they are suppliers for Halfords and others so cuts out a middle man so prices in theory should be cheaper IF they sold to the public.. With sizing if you want to use on top the arches - All You'd need to do to keep it from sticking out is just make it a little longer to compensate. I.e. rather than making a square shape or slightly rectangular make it a longer rectangular shape. Take the width of the arch and don't alter that figure but to get the correct internal volume just make it longer. make sense? KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
16th Jan 2013 6:16pm |
That was what I was trying to say It will travel up the arch by about 7/8 inches. It could be less if I utilized the awkward shape between the tub and arch, but that is a lot of hassle, and when you do the offside will foul the diesel filler !!! Its an additional 2.5 inches more than my current boxes. I'll have a play tomorrow.
Ps Google Armour, they have all the contact details on their site. |
16th Jan 2013 6:26pm |
I will I have been on their site before. Good luck with it. And I totally understand what you mean by hassle of odd size boxes I've had it. Best way I found was to make the best educated guess at the size that you can. Providing it isn't out by a lot it won't make any difference as there is give and take. The nearer the larger figure the better IMO as you get the better bass response then and lower frequency.
16th Jan 2013 6:54pm |
[][/i mg] Did that work ?? Trying to post a picture.... Computers are not my strong point !
The answer is no Trying to show you the dynamat Steve. In answer to your question yes covered everything except the roof and 2 doors up front. Added additional rubber matting so no there will be no exposed large metal surfaces which will dramatically change the acoustics of the stereo. Dynamat all the way It does a great job making things quieter (although it will always be noisier than a Bentley) But it changes the whole vehicle. |
18th Jan 2013 11:30am |
Have a look see here: http://www.defender2.net/forum/topic124.html
18th Jan 2013 11:42am |
Click image to enlarge][/img] Click image to enlarge Click image to enlarge Click image to enlarge |
18th Jan 2013 12:32pm |
Neatly done. That took some effort. KEEP CALM AND Drill ON
18th Jan 2013 12:47pm |
Job worth doing and all that WELL worth it. Was hoping to start refitting the ice, but tooooo much ice falling from the sky The hardest bit was cutting and sticking the new rubber matting. The heat gun had some use, and on my fingers
18th Jan 2013 12:58pm |
Just noticed.... Where's the other half of the accelerator pedal? KEEP CALM AND Drill ON
18th Jan 2013 3:34pm |
In a field about 4 years ago
18th Jan 2013 5:05pm |
What on earth were you up to. KEEP CALM AND Drill ON
18th Jan 2013 5:07pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
If it wasn't for the snow the back of mine would be fully dynamated now but I'll have to finish the rest off when it gets warmer and drier @ barbel Jim, top job
18th Jan 2013 5:35pm |
Enclosures made - all I need say is wow. Just got to finish, going to cover in the rubber matting to match the sides. Focal have stopped making the polyglass 6x9, so opted for something else. Sounds awesome, but my little active sub is somewhat lost........ Think I'm going to end up with a proper sub More expense and ear ache from the wife
25th Jan 2013 5:17pm |
