Home > Maintenance & Modifications > Extra legroom? Bulkhead Removal? Seat Rails?
Page 2 of 3 <123>
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
6' 2" and have the mud rails. make long trips comfortable.
OT - looks like we need a height Poll as many here seen above average height.
but that could be the slippery slope to a bald Poll or a weight Poll Neutral BM52
Post #199112 5th Jan 2013 12:12am
barbel jim
I'd steer well clear of an angle grinder, not just because an accidental slip could cause damage, but more because all those sparks tend to be little bits of hot metal. Easily burn into the clear top coat, and even glass. Once they burnt in , you'll never get them out, and they have a habit of corroding ! It is mostly ally to cut out, I did it with a jigsaw, hand hacksaw and a file simples.
I'm not too far away, Northampton, I'll give you a hand if you want. Thumbs Up
Post #199119 5th Jan 2013 6:57am
Mr B
TooTall wrote:
6'4'' Meh - Dwarf Rolling Eyes
I'm 6'6'' but the TD5 has no A/c so Laughing but pls let me know how you get on...
Same here 6' 6" in a TD5 90 CSW sans air con, but with mud rail... Leg rooms workable, just wish shoulder room was a little better. Hence the other car is a TDV8 RR. Driving that makes me feel petite! Smile
Post #199139 5th Jan 2013 9:34am
Tiger
5'11" and I find a standard Defender just fine.
Freaks! Laughing
Post #199143 5th Jan 2013 9:57am
dhopable
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
This is great guys, thanks! And yeh I think I'm gonna get a metal blade for the jigsaw and use that.
If your about Jim that be awesome! I could do with a bit of moral support! Thumbs Up
I do like the bulkhead with the half dog guard and wish I could keep it but my knee has other ideas with its close relationship with the dash! Sad Having done a few long trips recently I've just got to get something sorted..
I'll order the mud bar today but I reckon I've got some 3/4 box at work, could save on the £50 rails and mock some up.. Or is that too risky?
And yes us tall guys are freaks, it doesn't help with fitting on sports bikes either!! Dam genes!! Evil or Very Mad Thumbs Up
Post #199154 5th Jan 2013 11:05am
barbel jim
Pm me your number Bud and I'll give you a call.
I have ally spacers fitted by LR on mine with extended Bolts. Should think its about 30mm. Fronts are taller than the rears. can take some measurements if you like, But MUD stuff is good fits well and works with an oem feel.
Post #199170 5th Jan 2013 1:09pm
barbel jim
yes 30mm turned ally packers, 30mm wide with a hole in center for the longer bolts. Front is 40mm and rear 27mm high. Used to have something similar on my L200. Pick ups are renown for a poor seating position, Ie your bums too close to the floor, causing you to slump in your seat leading to the inevitable back ache. They were also supplied by the main dealer
Post #199218 5th Jan 2013 6:04pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Won't you be okay with the Mud Rails only? I'm 6'2" and comfortable without the rails. Probably wise to get the rails and see before you get the power tools out.
Post #199383 6th Jan 2013 1:12pm
JSG
Unless you remove the rear bulkhead you can't use the extra benefit of the Mudrails as the seat is already back against the bulkhead. John
2011 Tdci 110 CSW XS
Post #199384 6th Jan 2013 1:15pm
Thud
I thought the extra height allowed you to go back a bit as well.
Post #199389 6th Jan 2013 1:20pm
Storming
Scotland 2007 Defender 90 Puma 2.4 HT Blenheim Silver
Just done mine rails and bulkhead. ........ Great coz 6'2
S
Post #199393 6th Jan 2013 1:37pm
df1
I said it before but I cannot see the point in the mud rails. Just stick 2 m10 nuts under the 2 back bolts and it will slide over the lip.
Or as I did, cut 2 slots in the lip and the seat goes back without height adjustment. You'd need the bulkhead bar to get the most from this IMO.
Post #199399 6th Jan 2013 2:07pm
dhopable
Ok so your saying there's a simple way of doing it without buying the rails? Thumbs Up
I haven't had a proper look at them yet but do you mean you can cut that ledge away and the seat will slide back once the bulkhead is removed? Or by putting the nuts under will that lift the seat up to slide over? Or will that make the seat feel like its tipping forward...?
I suppose you can just put two nuts at the front as well and it would level it out? Confused Shocked
Post #199434 6th Jan 2013 4:55pm
barbel jim
Hi Doug,
I tried to call but unable to get through. Check your PM box Rolling Eyes
Post #199436 6th Jan 2013 5:01pm
Skippy R
United Kingdom 1998 Defender 90 300 Tdi SW Chawton White
I v'e put 2 over size nuts under my seat rails and used longer bolts to re-fit,works a treat Thumbs Up Dave
98 'S' 90 300Tdi (sold)
07 D3 HSE (now sold)
1993 Scania 143 450 (should have kept that ! )
Post #199446 6th Jan 2013 5:16pm
Page 2 of 3 <123>
