Home > In Car Electronics > The definitive Defender ICE thread
Page 14 of 71 <123 ... 131415 ... 697071>
Should be flat pins & an ISO connector which is universal. Thumbs Up KEEP CALM AND Drill ON
Post #187176 22nd Nov 2012 2:54pm
Need to do a little bit of fiddling soon with my Sub / sub box set up. I always knew I'd have to make it 100% sealed. So I will have to fit inside a way of keeping my existing cubby with opening lid but also seal the sub in AND get the internal air volume correct. Going to see if I can squeeze in 0.75 Cu3 FT. for maximum bass and lowest frequency.. Also going to add 50% Polyfill to trick the Sub into thinking it's in a larger enclosure than it really is. As it is with the Sub not being designed for free air use nor being sealed turn it up any good volume and the cubby lid will start hopping. Rolling with laughter
Watch this space. Thumbs Up KEEP CALM AND Drill ON
Post #187343 22nd Nov 2012 11:08pm
Defender-Stu
farmer giles wrote:
pioneer headunit and ipod
Hi,
May i ask how you got the ipod cable through the side to the passanger side shelf like in the picture as i cant seem to see a hole to do this?
Stu
Post #187429 23rd Nov 2012 11:17am
Stu - Talking for F-G Here (hope he doesn't mind) I think you'll find that it's probably a drilled hole. Anyone that has the Nak glove box could do the same also. Only reason I personally don't keep mine in that area is because it's on display and I don't like having to keep taking it out every 5 secs.
Post #187431 23rd Nov 2012 11:27am
Defender-Stu
Cheers Steve, i know what your saying re the on display, im not bothered as i also need the cable there for a future ipad nav mod and for the misses to use the ipad on long trips etc as is will charge the Apple items Thumbs Up , hope to be fitting my new HU soon so will let you know how i get on lol Thumbs Up
Post #187436 23rd Nov 2012 11:54am
Stu - I see what you mean now. Easier access for a passenger there too. If you have any trouble with your fitting of the the new HU you know who to come to / ask. Thumbs Up Thumbs Up KEEP CALM AND Drill ON
Post #187438 23rd Nov 2012 12:00pm
Defender-Stu
cheers mate will do, also how do i remove the center dash section as i see the 2 torx screws but cant see how the top coms off?
also will i need a lead to connect from the LR to the head unit?
Post #187449 23rd Nov 2012 1:01pm
BigRuss
remove the 2 screws, the radio, get some courage and pull! Thumbs Up Russell
2011MY 110 XS USW Black
Post #187458 23rd Nov 2012 1:24pm
Defender-Stu
Hi Bigruss, do i need some radio keys to get the thing out as dont seem to have any from LR?
Post #187462 23rd Nov 2012 1:31pm
Once you get the dash out you can release the stereo from behind
Post #187463 23rd Nov 2012 1:33pm
Defender-Stu
wicked Thumbs Up i will let you know how i get on Thumbs Up
also will i need a lead to connect from the LR to the new head unit?
Post #187467 23rd Nov 2012 1:37pm
Depends on the what is on the new unit, but very likely that they are both the same.
The only bit that maybe different is the aerial connection, but there are converters readily available on Ebay or Halfords for a few pounds
Post #187470 23rd Nov 2012 1:42pm
Defender-Stu
ok well the new unit it sony so should just be universal as in my old 2007 when i had a alpine its was a straight change, Cheers for the Help GB Thumbs Up
Post #187481 23rd Nov 2012 2:03pm
Martin
Site Admin
Moved to new forum section Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #187490 23rd Nov 2012 2:42pm
Martin - Thank-you. Mr. Green
Stu - Should be a straight fit mate fitting wise of the HU. You might need a single DIN fitting cage though. As I mentioned in previous post your more than welcome to pop over to mine if you like and I can show you / do it for you. Thumbs Up KEEP CALM AND Drill ON
Post #187499 23rd Nov 2012 3:07pm
