Home > Technical > MAF issue one week out of warranty
Page 3 of 3 <123
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
No strange scraping noises when driving - all seems fine. Not sure what you mean by the 5 chukka chukkas at shutdown - is this after engine switch off?
I will replace the MAF during the week and if there are still issues, will take to the dealer for "ignition learning".
Thanks for your help with this Brian
Post #182097 4th Nov 2012 9:15pm
Lorryman100
When you shut off the engine you will here the EGR going through it's self clean cycle and it sounds like 5 x chukka chukkas to me.
The procedure for: "P167B - 41 Fuel injector learning not done", is Pilot correction learn.
I do think that replacing the MAF will cure the MIL, and getting the injectors learned will help with the engine idle etc.
Let us know how you get on. Thumbs Up
Brian.
Post #182160 4th Nov 2012 10:29pm
kmac
Okay new MAF arrived, fingers corssed this rersolves all issues.......
Post #183139 8th Nov 2012 11:18am
kmac
MIL still came on Big Cry
NANOCOM - PUMAENG.APP - PUMA ENGINE fault file
167B - 41
missing CAN signal high/low switch
0100 - 64
Mass or volume air flow A circuit
signal plausibility failure
Only two codes now. Heard the chukka chukka of the EGR so don't think its that.
Does this mean a trip to the dealer for some "injector tuition"?
Post #183322 8th Nov 2012 10:38pm
If your EGR had a problem you would get the DTC come up so you haven't got that issue. How about taking it to main dealer they can check everything 100% then both by diagnostic and rectify any faults if any. It may just need all the software either updating or removing and replacing. A glitch as it were.. Although I am no expert. TheThunderRolls🇬🇧🇺🇸
Post #183328 8th Nov 2012 10:45pm
kmac
Puma Workshop manual says one of two things:
1) Pilot correction learning procedure corrupted
2) Engine control module (ECM) fault
Hoping its not the latter - anyone had an ECM replaced?
Post #183332 8th Nov 2012 11:01pm
kmac
167B - 41
0100 - 64
Dealer can only see the 0100 code. Will probably just end up with a new MAF harness.
Post #185462 16th Nov 2012 12:03am
tomdaprince
Netherlands 2007 Defender 90 Puma 2.4 HT Tonga Green
Hi kmac,
Have you managed to solve the P167B-41 DTC? I am having the same issue, car does pilot learn in standard map fine but gives E7 Failure when trying it in my BAS Remap using the BAS RRC. Fault code keeps returning to.
Post #514462 15th Mar 2016 9:29am
Page 3 of 3 <123
