![]() | Home > Technical > MAF issue one week out of warranty |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
When you shut off the engine you will here the EGR going through it's self clean cycle and it sounds like 5 x chukka chukkas to me.
The procedure for: "P167B - 41 Fuel injector learning not done", is Pilot correction learn. I do think that replacing the MAF will cure the MIL, and getting the injectors learned will help with the engine idle etc. Let us know how you get on. ![]() Brian. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
Okay new MAF arrived, fingers corssed this rersolves all issues.......
MIL still came on
![]() NANOCOM - PUMAENG.APP - PUMA ENGINE fault file 167B - 41 Fuel injector learning not done missing CAN signal high/low switch --- 0100 - 64 Mass or volume air flow A circuit signal plausibility failure --- Only two codes now. Heard the chukka chukka of the EGR so don't think its that. Does this mean a trip to the dealer for some "injector tuition"? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20696 ![]() ![]() |
If your EGR had a problem you would get the DTC come up so you haven't got that issue. How about taking it to main dealer they can check everything 100% then both by diagnostic and rectify any faults if any. It may just need all the software either updating or removing and replacing. A glitch as it were.. Although I am no expert. TheThunderRolls🇬🇧🇺🇸
Puma Workshop manual says one of two things:
1) Pilot correction learning procedure corrupted 2) Engine control module (ECM) fault Hoping its not the latter - anyone had an ECM replaced? |
Dealer can only see the 0100 code. Will probably just end up with a new MAF harness. |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 ![]() ![]() ![]() |
Hi kmac,
Have you managed to solve the P167B-41 DTC? I am having the same issue, car does pilot learn in standard map fine but gives E7 Failure when trying it in my BAS Remap using the BAS RRC. Fault code keeps returning to. |
