Home > Puma (Tdci) > Survey - Negative effects after a Puma TDCi is mapped?
BruceT
South Africa
Have you had any negative effects to a remap?
For example, have you had exhaust manifolds cracking, heat build up or any other negative effects?
Thank you
Post #180280 30th Oct 2012 9:25am
Naks
Not on the Puma.
I had the exhaust manifold warp on my Disco2 Td5 after I got it remapped, but that was a common issue on the Td5. --
Post #180285 30th Oct 2012 9:32am
BruceT
South Africa
I was about to email you Naks.... Smile
I also hadnt heard of this happening on a Puma and did experience it on my TD5 which was not remapped.
P.s. I took the plunge and ordered an Atric......... and its mostly your fault (and Regards)....now I have to wait. Sad
Post #180288 30th Oct 2012 9:38am
Naks
Nice, I'm sure you won't regret it. Gary knows what he's doing. Combined with your bigger intercooler, your landy will run like bomb! Thumbs Up --
Post #180289 30th Oct 2012 9:40am
BruceT
South Africa
like a bomb? Should I be worried..... lol
Back to topic now... Very Happy
Post #180290 30th Oct 2012 9:42am
bell-auto-services
You won't have a problem as safe limits are kept
Pete
Post #180292 30th Oct 2012 9:48am
BruceT
South Africa
Thank you Pete. This is exactly what I thought and to be honest half the reason I didnt choose the cheaper option and go local......
Post #180295 30th Oct 2012 10:04am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Problems......?........keeping my right foot of the accelerator Wink
None so far.
My car just started to use water 4 months after my remap and I was stressed as hell.
After multiple compression tests and coolant contamination tests by the dealers I was reasured that it was only my header tank cap that was leaking. A new tank and cap and 10 000km later my car has not used a drop of coolant again. So I think it is safe to say it was completely coinsidental.
Post #180339 30th Oct 2012 12:02pm
BruceT
South Africa
lol..... and meet the other guy whose fault it is I am asking this.... Very Happy
Post #180341 30th Oct 2012 12:04pm
llessur
Has anyone noticed if their ( don't laugh ) injectors seem noisy after a remap. Well I think it's injector noise. I have always presumed its down to the quality of fuel needing to be higher after a remap, but I would love someone to correct me as I really don't know. I guess I ought to treat it to a tank full of BP Ultimate or similar to find out.
As always your wisdom would be appreciated.
Post #180393 30th Oct 2012 4:19pm
As far as problems go I expect more tyre wear & brake wear would be about all you'd expect and maybe chutches too. Other than that. I don't think in standard tune they are exactly slow anyway.. No Guts, No Glory.
Post #180394 30th Oct 2012 4:23pm
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Over all mines been super,pulls well in all gears, but has a massive flat spot if changing gear fast Sad
But happy.
Post #180481 30th Oct 2012 8:10pm
pannawonica
Australia
[quote="llessur"]Has anyone noticed if their ( don't laugh ) injectors seem noisy after a remap. Well I think it's injector noise. I have always presumed its down to the quality of fuel needing to be higher after a remap, but I would love someone to correct me as I really don't know. I guess I ought to treat it to a tank full of BP Ultimate or similar to find out.
As always your wisdom would be appreciated.[/quote]
Extra noise maybe due to increased injector pressure, mine did the same. However @ coke full of 2SO per tank the engine is quieter and smoother pre remap. Thumbs Up
Post #180535 31st Oct 2012 2:01am
Naks
Yep, there is a bit of extra noise, but that's normal. 2SO definitely quietens things down --
Post #180536 31st Oct 2012 4:39am
BruceT
South Africa
Ive never used 2SO. Please send me the details of what you use.
Thx Naks.
Post #180542 31st Oct 2012 5:49am
