Home > Puma (Tdci) > Survey - Negative effects after a Puma TDCi is mapped? |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
Thanks Regard.
Do I just add the bottle to the tank when I fill up? (i have a 120 litre tank) |
31st Oct 2012 6:18am |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 |
Yes Bruce
In your case one bottle (500ml) per tank. (+_ 1:200 mix) Dump it in there just before they fill up. I also have a 100l tank (extra tank) so I just split mine 50% in the main tank and 50% in longrange tank. |
31st Oct 2012 6:22am |
Thanks Regard.
So thats the only negative effects that have been experienced? |
31st Oct 2012 6:25am |
Just to clarify....
I've never heard a change in my engine noise? Well...I've been using 2so even before the remap but infact, I think the engine runs even more smooth after the remap! |
31st Oct 2012 6:32am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
Bruce, I just chuck in a bottle (200ml) of the Sasol 2SO when I fill up there. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
31st Oct 2012 7:11am |
ok thanks....will try with my next tank full.
31st Oct 2012 7:19am |
GREENPUMA Member Since: 12 Feb 2010 Location: devon Posts: 17 |
Have an '07 110 with Alive 'light' re-map. It made a big difference to torque profile. Pulled easily in 6th from 40mph instead of 50mph. Then fitted a S/S de-catted 3"diameter sports exhaust system with only a very small silencer at the back, and now transformed the vehicle again. Very much smoother, quieter, apart from the bark at the back when pulling hard. Slight drop in mpg, but that might be the driving-style since fitting the exhaust
14th Dec 2012 7:33pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
overall re-map great and pulls hard from low down......only small thing so far is occasional hiccup when coming from over-run and back onto the throttle or when changing up through the gears. Hardly noticable so it is no real problem. the rest is all positive
15th Dec 2012 4:14pm |
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 |
My map is fine
15th Dec 2012 5:25pm |
