Home > Puma (Tdci) > EGR Valve Cleaning!
Page 10 of 12 <123 ... 9 101112>
ZeDefender
I will do everything in my power to avoid the EGR valve - I can't even see the bolts, let alone get my hand in Shocked
I wonder if it's even worse in LHDs...
In theory, (almost) blanking off at the manifold end will massively reduce the amount of soot the valve has to deal and possibly increase its life Confused Tell someone you love them today because life is short.
Post #177661 21st Oct 2012 12:25pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Mine's LHD as well, it's accessible, just that #@+*&% hose clip that stops me from removing the EGR... No way the socket can reach the bolt, the clip is placed right in front of the bolt Twisted Evil
That's too bad because I purchased item #110934139626 on ebay which is the right blanking plate to go between the EGR and the cooler. It's got open holes as well so no need to remove the valve entirely.
Oh well, I guess I'll just add the plate when replacing the the EGR valve when it eventually dies.
Post #177675 21st Oct 2012 2:24pm
ZeDefender
Really don't understand why you'd fit the blanking plate right next to the EGR Confused
The manifold/pickup joint is p*ss easy to get to and blocks off most of the smoke before it even gets out of the manifold... Tell someone you love them today because life is short.
Post #177682 21st Oct 2012 2:52pm
o4dn
Have you found those on ebay for the Puma 2.4 Defender? I haven't... The one I found goes between the cooler and the valve itself.
Maybe it's better for the plate to be placed after the cooler rather than directly on the exhaust manifold? Just random thought, no hard evidence of that.
Post #177683 21st Oct 2012 2:59pm
ZeDefender
No - none on eBay but the ones K9F is sending me are positioned at the manifold with no problems. I intend to make modified versions that slip in and out just by loosening the nuts without taking out the studs - 5 minute job then, tops.
They may need changing depending on tuning, air temperature etc. I should know in a couple of weeks Thumbs Up
p.s for now you could just unplug your EGR valve to give it a rest and run with the MIL on - it only comes on after 3 engine cycles and can simply be cancelled if you have a Scangauge II etc. Tell someone you love them today because life is short.
Post #177691 21st Oct 2012 3:28pm
ZeDefender
Mal's blanks arrived this morning Mr. Green
Just have to get a bit fitter (SWMBO insists stitches come out first) and I'm off. Slightly worried about forecast for snow this weekend Shocked but I'm sure I'll find a warm dry place to experiment in the next few weeks Wink
Thanks again Mal Thumbs Up
Matt Tell someone you love them today because life is short.
Post #178591 24th Oct 2012 11:37am
K9F
Welcome..... Thumbs Up Glad they arrived, dependant on swelling you could always play with your 'old man' and check on swelling reduction by trying to pass him through the blank orifices on a daily basis. Start with the 20mm one first.....
Rolling with laughter
Wishing you a speedy recovery. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #178622 24th Oct 2012 1:56pm
ZeDefender
Rolling with laughter Shocked Tell someone you love them today because life is short.
Post #178631 24th Oct 2012 2:30pm
Any progress Matt? Or are you too busy destroying the air box. Surprised ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #181705 3rd Nov 2012 4:55pm
ZeDefender
Airbox destroyed (well, the propeller thing anyway) and my mate Thomas is making the new blanks - the ones that just slot in. Just hope there's enough room for slotting in, as the manifold joint is opposite a bracket on the bulkhead...
I've also decided which intercooler I want (again from Thomas):
http://www.offroadservice.net/defender-tun...fender.php
Guts are better so I'd better get on with things Wink Tell someone you love them today because life is short.
Post #181799 3rd Nov 2012 9:18pm
Yep, you can get your arse in gear now. Thumbs Up If I remember correctly your going to try and blank the manifold side and not right next to the EGR? Have I got that right? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #181808 3rd Nov 2012 9:56pm
ZeDefender
Yup Tell someone you love them today because life is short.
Post #181812 3rd Nov 2012 10:00pm
Basically more or less the whole EGR system will be voided then except for a much reduced gas flow to keep the EGR still going but at a reduced rate. Sounds good to me. To be honest I can't understand why blanks like these or kits aren't readily available? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #181813 3rd Nov 2012 10:03pm
ZeDefender
Yup - it's an old story, hence the blanks Mal sent me which in turn came from Robofarmer. I just wanted to make some that are quick to change out on the newer Pumas (keeping the studs not changing to bolts) and to test them as objectively as possible. Most interesting will be to see how the hole size needs to vary with intercooler, decat and remap. In addition, when using an EGR-off remap, the holed blank will keep most of the soot away from the EGR valve, prolonging its life (even when inactive). Tell someone you love them today because life is short.
Post #181817 3rd Nov 2012 10:18pm
Ze - anything happened / been done with this yet or have you not had the chance / items to do it? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #187087 21st Nov 2012 11:41pm
