![]() | Home > Puma (Tdci) > EGR Valve Cleaning! |
FoD 90,
You have got to have some form of record with four replacements....21,000 miles first replacement for me! Maybe we should canvass for EGR Valve changes, someone somewhere may see it and try to get a suitable resolution for one and all??? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Forest of Dean 90 Member Since: 29 Apr 2009 Location: Forest of Dean Posts: 68 ![]() ![]() ![]() |
I hope a solution can be found, because its not funny if you happen to be gong down the Motorway at the time and loss power!!
But as the Wagon has been in the Stealers for the last 2 weeks awaiting a New Gearbox (none in stock on back order and no one knows when they will be supplied) the EGR is the least of my problems... |
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 ![]() ![]() |
Need to treat it as a service item I believe, just had dual failure on our Disco, luckily 2 weeks left on the warranty!
![]() Its not LR/Ford specific however, weakest part of a diesel engine someone was telling me the other day, they all put them in due to emissions. |
I could be wrong here but I am led to believe that EGR Valves are fitted to remove a specific emmitted gas monitored on the US side of the Atlantic. The same specific gas is not looked for in the UK. The name of the gas escapes me ( ![]() Treat every day as if it is your last....one day you will be right!! |
[quote="K9F"]
The name of the gas escapes me there exhaust gases K9 ![]() 1968 1/32 scale Britains 109 Pick up. Last edited by Grockle on 20th Apr 2010 10:23am. Edited 1 time in total |
I do believe they effect uk emissions at MOT, or so I was told...
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2458 ![]() ![]() ![]() |
The symptom of lack of power is gradual or it happens suddenly? Puma 110" SW
On our Disco it was lack of power, slow away from junctions, until it went completely, then it was foot to the floor resulting in 1500RPM and no real motion!
MK,
The power loss experienced top end was a sensation of the vehicle momentarily hanging back accelerating and then hanging back again whilst the accelerator was constant (foot to the floor). Lower end only happened a couple of times but is exactly as TallPaul describes pulling off from a standing start - nothing happens!!! Grockle ![]() ![]() ![]() ![]() ![]() 15:35 update: Just been informed that my vehicle is ready and the EGR Valve has been replaced. They also stated that they were unwilling to road test it as they deem my Mach 5s tyre width/slight protrudance as illegal. Not bothered as it will keep another 'oily rag' out of my driver's seat, after all I shall road test it myself. Only I am allowed to cane it! Happy days! Hopefully! ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
The EGR valve recirculate, in same engine rpm, Temp, and load conditions, controlled part of exhaust gases to the inlet manifold.
In this way the engine run with lower combustion temperature and produce less NOx LINK1 LINK2 In modern diesel engines, the EGR gas is cooled through a heat exchanger to allow the introduction of a greater mass of recirculated gas. Unlike SI engines, diesels are not limited by the need for a contiguous flamefront; furthermore, since diesels always operate with excess air, they benefit from EGR rates as high as 50% (at idle, where there is otherwise a very large amount of excess air) in controlling NOx emissions. Since diesel engines are unthrottled, EGR does not lower throttling losses in the way that it does for SI engines (see above). However, exhaust gas (largely carbon dioxide and water vapor) has a higher specific heat than air, and so it still serves to lower peak combustion temperatures. There are trade offs however. Adding EGR to a diesel reduces the specific heat ratio of the combustion gases in the power stroke. This reduces the amount of power that can be extracted by the piston. EGR also tends to reduce the amount of fuel burned in the power stroke. This is evident by the increase in particulate emissions that corresponds to an increase in EGR. Particulate matter (mainly carbon) that is not burned in the power stroke is wasted energy. Stricter regulations on particulate matter(PM) call for further emission controls to be introduced to compensate for the PM emissions introduced by EGR. The most common is particulate filters in the exhaust system that result in reduced fuel efficiency. Since EGR increases the amount of PM that must be dealt with and reduces the exhaust gas temperatures and available oxygen these filters need to function properly to burn off soot, automakers have had to consider injecting fuel and air directly into the exhaust system to keep these filters from plugging up. EGR deletion EGR deletion in diesel engines is considered justifiable by a wide range of people, including the environmentally conscious. Although deleting the EGR system results in increased NOx level; hydrocarbon emissions, particulates, carbon monoxide and carbon dioxide are drastically reduced. Furthermore, EGR deletion results in an increase in fuel economy as high as 25%. Exhaust gas recirculated back into the cylinders adds wear-inducing contaminants and causes an increase engine oil acidity, which can result in an inefficient, poorly running engine. The increased level of soot also creates the need for diesel particulate filters to prevent environmental contamination. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
So Daniele, do you still have the MIL on? I would like to get as much as 25% fuel economy.... Puma 110" SW
yes, my mil in ALWAYS on ![]() 25% is a little optimistic but a good 10-12% is a real value..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
NOx or nitrous oxide was the name of the gas 'that escaped me'
![]() Still hope that someone can come up with a resolution to blank or bypass without a MIL light coming on! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Drove the vehicle after my EGR Valve replacement and due to reprogramming
![]() ![]() Autologic are currently working on the case (as it means a loss of revenue) and the upshot is I shall get a free reload of my map as soon as one is available...Bummer! ![]() In the interim I have to put up with my 'underperforming' Defender...this is undoubtedly going be psycologically damaging for me, but a possible relief for other road users! Never mind, if the weather holds will have to get the bike out for thrills instead, that is of course if I can get my fat lardy ar5e in my leathers! ![]() ![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
