![]() | Home > Technical > MAF issue one week out of warranty |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
I'd see how it goes for now but if it keeps on going on and off over say a period of 6 weeks then I would just replace the MAF sensor. If you have cleaned it and still have the issue as you say I doubt you'll have much choice. On the bright side they are relatively cheap �30 - �40 ish and fairly easy to change. There are also some good guides and pictures on here to help guide you in change it. It's easy though.. WeWillWin🇬🇧🇺🇸
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Fairly easy to change??? I'd say so, one electric plug and 2 screws. Just make sure you have the arrow pointing in the right direction.
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
Yeah, agree, trivial to change. I did have to remove it to clean so replacing would be a doddle. Also noticed the "arrow" on it for the flow.
Any idea where I can get a replacement? And are these made by Land Rover? I saw one on FirstFour for about �40. |
Also doing some research on here (Def2.net) P0100 is supposed to be an "untested" DTC so why the MIL?
For a replacement MAF I would choose from either Paddock spares. Or Duckworth LR (Site sponsor) Or Shukers Parts LR. All good prices all reliable.
Thanks |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
It is a untested dtc when the MIL is not illuminated. When the MIL is lit and P0100 is the only dtc logged then it is a tested DTC because it failed the self test hence why the MIL is lit. Any dtc to do with emissions, that logs a tested dtc will illuminate the MIL. Also the Autel is VAG specific meaning it can read the generic faultcodes P0---, but not the manufacturer specific codes that apply on your Puma, P1----,P2----,P3----,U0----,U1---- etc. So you may not have the full story in what is causing the MIL as the Autel can only read the logged P0100 dtc. The actual Ford dtc explanation for P0100 is: P0100 Mass or Volume Air Flow "A" Circuit Some light reading on what a dtc is: There are basically two types of DTC codes for OBDII Diagnostics: Emissions related DTC's Tested DTC's Type A 1. Emissions related. 2. The Malfunction Indicator Lamp (MIL) will be illuminated as soon as the error occurs. 3. Stores a freeze frame DTC after one failed driving cycle.( history DTC is stored ) Type B 1. Emissions related. 2. Sets a Pending Trouble Code after one failed driving cycle. 3. Clears a Pending Trouble Code after one successful driving cycle. 4. Turns on the MIL after two/three consecutive failed driving cycles. 5. Stores a Pending Trouble Code as a DTC after two consecutive failed driving cycles. Conditions for Clearing the MIL/DTC � Type A or Type B The MIL will turn off after four consecutive driving cycles in which the diagnostic runs without a fault. A history DTC will clear after 40 consecutive warm up cycles without a fault. DTC(s) can be cleared by using a scan/diagnostic tool. Non�Emissions Related DTCs Un Tested DTC's Action Taken When the DTC Sets 1. The Malfunction Indicator Lamp (MIL) will not illuminate. 2. The ECM will record a DTC at the time the diagnostic fails. Conditions for Clearing the DTC A history DTC will clear after 40 consecutive warm up cycles without a fault. DTC(s) can be cleared by using a scan/diagnostic tool. How to read a DTC Code The DTC value will help you narrow down the specific component or module in question. A DTC has a standardized format that can be interpreted as follows: The first part of the DTC is the Alpha Designator. The alpha designator will be: B - Body electronics (i.e., door and hood latches) C - Chassis (i.e., traction control or ABS) P - Powertrain (i.e., engine, transmission) U - Network communications for the different control modules Second Digit - Code Type The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code. 0 = Generic (The diagnostic codes that are required by law on all OBD II systems are "generic" in the sense that all vehicle manufacturers use the same common code list and the same 16-pin diagnostic connector. Thus, a P0301 misfire code on a Ford means the same thing on a Vauxhall, Citroen, Toyota or Mercedes.) 1 = Enhanced ( Each vehicle manufacturers also have the freedom to add their own "enhanced" codes to provide even more detailed information about various faults. Enhanced codes also cover non-emission related failures that occur outside the engine control system. These include ABS codes, HVAC codes, airbag codes and other body and electrical codes.) Third Digit - Sub-System The third digit denotes the type of sub-system that pertains to the code 1 = Emission Management (Fuel or Air) 2 = Injector Circuit (Fuel or Air) 3 = Ignition or Misfire 4 = Emission Control 5 = Vehicle Speed & Idle Control 6 = Computer & Output Circuit 7 = Transmission 8 = Transmission 9 = SAE Reserved 0 = SAE Reserved Fourth and Fifth Digits These digits, along with the others, are variable, and relate to a particular problem code error number So let's diagnose a DTC, I've picked P0404-73 EGR control circuit range/performance: actuator stuck closed so we have: P = Powertrain (engine, transmission) 0 = Generic 4 = Emissions control 0 4 =This is the specific error code within Emission control. In this case the EGR control circuit range/performance -73= This is a specific problem, in this case the actuator is stuck closed. P0404-72 means its stuck open. Just my tuppence worth ![]() |
Excellent write up Brian. Very interesting read.
Hi Brian, thanks for the detailed explanation. Was aware the VAG is VW/Audi specific (I have it for my Golf). A nanocom is on its way to me so I should have the "full" picture very soon.
Will post on here what it says. |
So after cleaning the MAF sensor with carb cleaner, the MIL has not come on again (yay!)
However, not that I have a Nanocom Evo, I plugged it in and found a few codes logged. Will post on here once I work out how to save them to a txt file. |
If you want .txt type file just open Notepad and save from there. That's how I get that file type. ![]() ⛽️🛢️⚙️🧰💪 |
Ok damn MIL came on again. Nanocom came up with the following:
NANOCOM - PUMAENG.APP - PUMA ENGINE fault file 167B - 41 Fuel injector learning not done missing CAN signal high/low switch --- 0100 - 64 Mass or volume air flow A circuit signal plausibility failure --- 0404 - 72 Exhaust gas recirculation (EGR) control circuit range/performance actuator stuck open --- 0299 - 00 Turbocharger A under boost condition --- 0234 - 00 Turbocharger A over boost condition I note the MAF error still there - may try replacing the MAf - however it refers to the circuit rather than the sensor itself Also anything I can do re EGR actuator being stuck open? |
I've found one for you
![]() http://www.ebay.com.au/itm/NEW-air-flow-ma...15[/quote] ![]() |
Thanks Laurie, that was really helpful.....
apart from the price of course and the fact that's it not the right part ![]() |
