Home > Technical > MAF issue one week out of warranty
Page 1 of 3 123>
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Ha...warranty ran out end of Sep. Last week car went into body shop as I reversed into a bollard (low and unseen).
Came back with MIL on. Anyway body shop was insistent on quoting to have MIl reset (and they kept insisting that my ABS light was also on, in spite of me telling them that it goes off after reaching 5mph).
Have a VAG405 by Autel for my Golf which whilst having VW and AUDI specific codes also has an OBD2 code reader - plugged in and it came up with
P0100 -Mass air flow (MAF) sensor/volume air flow (VAF) sensor - circuit malfunction Wiring, MAF/VAF sensor, ECM
Erased code and left it at that - that was yesterday. Took it for a spin all was well.
This morning MIL again. Same code. So I removed the MAF and spayed with some carb cleaner. Let it dry and replaced MAF and cleared code again. Took it for a longer drive, MIL stayed un-lit.
Anyway - looked on here and never noticed P0100 on its own, always with something else. Could dust etc at body shop have caused this? Is next step to replace MAF if MIL lights up again?
Post #175654 14th Oct 2012 2:09pm
I'd see how it goes for now but if it keeps on going on and off over say a period of 6 weeks then I would just replace the MAF sensor. If you have cleaned it and still have the issue as you say I doubt you'll have much choice. On the bright side they are relatively cheap £30 - £40 ish and fairly easy to change. There are also some good guides and pictures on here to help guide you in change it. It's easy though.. WeWillWin🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #175657 14th Oct 2012 2:21pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Fairly easy to change??? I'd say so, one electric plug and 2 screws. Just make sure you have the arrow pointing in the right direction. Cool
Post #175658 14th Oct 2012 2:34pm
kmac
Yeah, agree, trivial to change. I did have to remove it to clean so replacing would be a doddle. Also noticed the "arrow" on it for the flow.
Any idea where I can get a replacement? And are these made by Land Rover? I saw one on FirstFour for about £40.
Post #175662 14th Oct 2012 2:38pm
kmac
Also doing some research on here (Def2.net) P0100 is supposed to be an "untested" DTC so why the MIL?
Post #175664 14th Oct 2012 2:40pm
For a replacement MAF I would choose from either Paddock spares. Or Duckworth LR (Site sponsor) Or Shukers Parts LR. All good prices all reliable. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #175668 14th Oct 2012 3:07pm
kmac
Thanks
Post #175674 14th Oct 2012 3:32pm
Lorryman100
It is a untested dtc when the MIL is not illuminated. When the MIL is lit and P0100 is the only dtc logged then it is a tested DTC because it failed the self test hence why the MIL is lit. Any dtc to do with emissions, that logs a tested dtc will illuminate the MIL.
Also the Autel is VAG specific meaning it can read the generic faultcodes P0---, but not the manufacturer specific codes that apply on your Puma, P1----,P2----,P3----,U0----,U1---- etc. So you may not have the full story in what is causing the MIL as the Autel can only read the logged P0100 dtc.
The actual Ford dtc explanation for P0100 is: P0100 Mass or Volume Air Flow "A" Circuit
Some light reading on what a dtc is:
There are basically two types of DTC codes for OBDII Diagnostics:
Emissions related DTC's Tested DTC's
Type A
1. Emissions related.
2. The Malfunction Indicator Lamp (MIL) will be illuminated as soon as the error occurs.
3. Stores a freeze frame DTC after one failed driving cycle.( history DTC is stored )
Type B
2. Sets a Pending Trouble Code after one failed driving cycle.
3. Clears a Pending Trouble Code after one successful driving cycle.
4. Turns on the MIL after two/three consecutive failed driving cycles.
5. Stores a Pending Trouble Code as a DTC after two consecutive failed driving cycles.
Conditions for Clearing the MIL/DTC – Type A or Type B
The MIL will turn off after four consecutive driving cycles in which the diagnostic runs without a fault.
A history DTC will clear after 40 consecutive warm up cycles without a fault.
DTC(s) can be cleared by using a scan/diagnostic tool.
Non–Emissions Related DTCs Un Tested DTC's
Action Taken When the DTC Sets
1. The Malfunction Indicator Lamp (MIL) will not illuminate.
2. The ECM will record a DTC at the time the diagnostic fails.
Conditions for Clearing the DTC
How to read a DTC Code
The DTC value will help you narrow down the specific component or module in question. A DTC has a standardized format that can be interpreted as follows:
The first part of the DTC is the Alpha Designator. The alpha designator will be:
B - Body electronics (i.e., door and hood latches)
C - Chassis (i.e., traction control or ABS)
P - Powertrain (i.e., engine, transmission)
U - Network communications for the different control modules
Second Digit - Code Type
The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code.
0 = Generic (The diagnostic codes that are required by law on all OBD II systems are "generic" in the sense that all vehicle manufacturers use the same common code list and the same 16-pin diagnostic connector. Thus, a P0301 misfire code on a Ford means the same thing on a Vauxhall, Citroen, Toyota or Mercedes.)
1 = Enhanced ( Each vehicle manufacturers also have the freedom to add their own "enhanced" codes to provide even more detailed information about various faults. Enhanced codes also cover non-emission related failures that occur outside the engine control system. These include ABS codes, HVAC codes, airbag codes and other body and electrical codes.)
Third Digit - Sub-System
The third digit denotes the type of sub-system that pertains to the code
1 = Emission Management (Fuel or Air)
2 = Injector Circuit (Fuel or Air)
3 = Ignition or Misfire
4 = Emission Control
5 = Vehicle Speed & Idle Control
6 = Computer & Output Circuit
7 = Transmission
8 = Transmission
9 = SAE Reserved
0 = SAE Reserved
Fourth and Fifth Digits
These digits, along with the others, are variable, and relate to a particular problem code error number
So let's diagnose a DTC, I've picked P0404-73 EGR control circuit range/performance: actuator stuck closed
so we have:
P = Powertrain (engine, transmission)
0 = Generic
4 = Emissions control
0 4 =This is the specific error code within Emission control. In this case the EGR control circuit range/performance
-73= This is a specific problem, in this case the actuator is stuck closed. P0404-72 means its stuck open.
Just my tuppence worth Thumbs Up
Post #176261 16th Oct 2012 4:56pm
Excellent write up Brian. Very interesting read. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #176264 16th Oct 2012 4:57pm
kmac
Hi Brian, thanks for the detailed explanation. Was aware the VAG is VW/Audi specific (I have it for my Golf). A nanocom is on its way to me so I should have the "full" picture very soon.
Will post on here what it says.
Post #176362 16th Oct 2012 9:15pm
kmac
So after cleaning the MAF sensor with carb cleaner, the MIL has not come on again (yay!)
However, not that I have a Nanocom Evo, I plugged it in and found a few codes logged. Will post on here once I work out how to save them to a txt file.
Post #177422 20th Oct 2012 1:24pm
If you want .txt type file just open Notepad and save from there. That's how I get that file type. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #177428 20th Oct 2012 2:14pm
kmac
Ok damn MIL came on again. Nanocom came up with the following:
NANOCOM - PUMAENG.APP - PUMA ENGINE fault file
167B - 41
Fuel injector learning not done
missing CAN signal high/low switch
0100 - 64
Mass or volume air flow A circuit
signal plausibility failure
0404 - 72
Exhaust gas recirculation (EGR) control circuit
range/performance
actuator stuck open
0299 - 00
Turbocharger A under boost condition
0234 - 00
Turbocharger A over boost condition
I note the MAF error still there - may try replacing the MAf - however it refers to the circuit rather than the sensor itself
Also anything I can do re EGR actuator being stuck open?
Post #181654 3rd Nov 2012 3:14pm
Laurie
Post #181656 3rd Nov 2012 3:32pm
kmac
Thanks Laurie, that was really helpful.....
apart from the price of course
and the fact that's it not the right part Rolling Eyes
Post #181662 3rd Nov 2012 3:46pm
Page 1 of 3 123>
