Home > Technical > Installing reversing camera
Page 1 of 6 123456>
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Installing a reversing camera but not planning to wire into the reversing light. Instead I want to have a switch on the dash that I can use to control ignition power to the camera and screen.
So, couple of questions:
1) Can I use a switch such as a rear fog light switch to do the job?
2) What is the easiest place to get ignition live from if I plan to put the switch where there is a current "blank" in the Puma (top next to heated windscreen switch)?
Post #176986 18th Oct 2012 10:48pm
kmac
Actually worked out what switch I need (heated seat switch will work and costs only circa ฃ5)
Just need to work out best place to get ignition live from
Post #176990 18th Oct 2012 10:58pm
HU ignition live? Seeing as the whole set up is used in conjunction. $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #177063 19th Oct 2012 10:35am
kmac
Sorry HU a bit too cryptic for me - what's that please?
Post #177142 19th Oct 2012 2:47pm
Sorry, HU meaning Head Unit. Your CD player / radio. $W33T $0U7H3RN $UG4R
Post #177149 19th Oct 2012 3:06pm
kmac
Aah okay thanks - thats was my thought, using the stereo, just needed a second opinion.
Low amps drawn ( only 3amp fuse needed for camera and screen) so should be okay.
Post #177159 19th Oct 2012 3:38pm
Your welcome. At least this way depending on which part of the wiring loom you use it's replaceable if you need to in the future instead of butchering a part of the existing vehicle wiring. Smile I guess if you really wanted to go the whole hog you could have a 3 way switch which you could have ON OFF and Reverse but you'd have to wire into the ignition AND reverse but all possible and gives you more functionality. Why is it you don't really want to tap into the reverse ma I ask? $W33T $0U7H3RN $UG4R
Post #177169 19th Oct 2012 4:01pm
kmac
No particular reason, want to keep it simple and also be able to see what's at the rear without putting car into reverse gear.
My screen allows for two camera's so maybe at same later stage I may install another camera that's linked to the reverse light.
Post #177235 19th Oct 2012 7:06pm
Oh I see what you mean. That could be useful towing a trailer I'd have thought.. $W33T $0U7H3RN $UG4R
Post #177236 19th Oct 2012 7:08pm
kmac
One other thing, with the radio harness, how do I know which wire is live, earth etc? Do I just need to check with a multi-meter?
I had a look at the "complete electrical connector manual" but as far as I can see that just shows source and destination of Pins in a plug - doesn't tell you what each pin is though.
Post #177329 19th Oct 2012 11:59pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I've picked up live feed from this loom.
There are two feeds....one permanent live..the other live with ignition on.
Can't remember the colours but I just unplugged the ISO connector and metered each connection.
Then connected in with scotch locks
Dead simple
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadsterโ€ฆโ€ฆ..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #177332 20th Oct 2012 4:35am
Happyoldgit
Scotchlocks <shudder> Steve.
http://forums.lr4x4.com
Post #177375 20th Oct 2012 9:04am
I cannot guarantee it so make sure you check first but normally the ignition is Yellow and the permanent live Red. $W33T $0U7H3RN $UG4R
Post #177392 20th Oct 2012 10:15am
kmac
Thanks chaps - task for next weekend now as tied up this weekend
Post #177418 20th Oct 2012 11:51am
WarPig
How's the install going? Which screen & camera did you buy? I'm looking at installing one myself soon.
Post #181359 2nd Nov 2012 4:44pm
Page 1 of 6 123456>
