![]() | Home > Technical > Installing reversing camera |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 ![]() ![]() ![]() |
Actually worked out what switch I need (heated seat switch will work and costs only circa £5)
Just need to work out best place to get ignition live from |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
HU ignition live? Seeing as the whole set up is used in conjunction. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Sorry HU a bit too cryptic for me - what's that please? |
Sorry, HU meaning Head Unit. Your CD player / radio. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Aah okay thanks - thats was my thought, using the stereo, just needed a second opinion. Low amps drawn ( only 3amp fuse needed for camera and screen) so should be okay. |
Your welcome. At least this way depending on which part of the wiring loom you use it's replaceable if you need to in the future instead of butchering a part of the existing vehicle wiring.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
No particular reason, want to keep it simple and also be able to see what's at the rear without putting car into reverse gear.
My screen allows for two camera's so maybe at same later stage I may install another camera that's linked to the reverse light. |
Oh I see what you mean. That could be useful towing a trailer I'd have thought.. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
One other thing, with the radio harness, how do I know which wire is live, earth etc? Do I just need to check with a multi-meter?
I had a look at the "complete electrical connector manual" but as far as I can see that just shows source and destination of Pins in a plug - doesn't tell you what each pin is though. |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1231 ![]() ![]() ![]() |
I've picked up live feed from this loom.
There are two feeds....one permanent live..the other live with ignition on. Can't remember the colours but I just unplugged the ISO connector and metered each connection. Then connected in with scotch locks Dead simple Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadsterβ¦β¦..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
Scotchlocks <shudder> Steve.
I cannot guarantee it so make sure you check first but normally the ignition is Yellow and the permanent live Red. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Thanks chaps - task for next weekend now as tied up this weekend
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
How's the install going? Which screen & camera did you buy? I'm looking at installing one myself soon.
