Home > Technical > Installing reversing camera |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Haven't gotten round to it yet. Been too wet to consider. Also had to order a few bits for the install.
I got a bullet CCD camera and 5" screen from http://shop.reversingcamerasuk.com/ There are cheaper kits available on ebay though. I've also got all the other bits I need: 1) Cable conduit 2) Cable ties 3) Switch for dash (I'm going to have it switched rather than hooked into the reversing light) |
2nd Nov 2012 7:14pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Great. Any photos of your installation please?
Reversing camera is still on my to do list. |
27th May 2013 8:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20337 |
Did you directly tap in or add a small extension section to the existing to avoid damaging the original loom? $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
27th May 2013 8:26pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
H'mm, IIRC it is just the other way round, i.e. red = ignition live, yellow (or orange) = permanent live (for radio memory). Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
27th May 2013 8:43pm |
I actually tapped in using scotch locks - not ideal but I wanted the set-up to work before I set about soldering. Original loom not damaged in any way. Also, took a connection from another switch for the "console illumination" WarPig - will post some pics later on today - raining again at the moment |
28th May 2013 7:30am |
According to this - seems like White/orange is ignition live and Purple/Brown is permanent live Click image to enlarge |
28th May 2013 7:40am |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
just an idea:
I used the spare switch on the dash (LR uses it for SVX-Fog lights or whatever I think) to switch on the reversing camera. I took a Discovery-2 SLC-Switch, because I could easily get one, it will stay in the "on"-position if pressed, but it has red backlight at night. I still used it because it works with the connector that also is used for the elect.windscreen-switch which I conincidentally had too. On the plus-side the SLC-Switch has a symbol that somehow makes sense. I used a sharp blade to scratch away some of the grey switch´s surface to alter the symbol. In case you want a different backlight, you have to take another switch and could use the SLC- front knob with it. All interchangeable. Don´t want to bother you with the stories of camera installations. But the camera also was a popular topic there, should be several pics: http://www.blacklandy.eu/blboard/forum/sho...fahrkamera |
31st May 2013 8:11am |
Pics as promised....
1) Bullet camera installed in existing hole in cross member ( used part of a bicycle inner tube to insulate camera from cross member (bi-metal corrosion and all that) Click image to enlarge 2) Cable routed along chassis in conduit and secured using cable ties Click image to enlarge 3) Cable enters vehicle under drivers seat 4) Carefully routed under carpet to dash and connected to switch - used a seat heating switch (cheap at £5 but need to change the icon - any ideas?) Click image to enlarge 5) Cable not very tidy when screen in use - need to think of a more elegant solution but I need a removable screen to prevent theft Click image to enlarge 6) Works - bright sunlight so photo of screen doesn't do it justice - image is really clear Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by kmac on 28th Dec 2013 7:24am. Edited 1 time in total |
1st Jun 2013 12:44pm |
Used this connector to connect wiring to switch
Available on fleabay http://www.ebay.co.uk/itm/LAND-ROVER-5-Way...257db8e040 Spare seat heater switch via Duckworth Parts (thanks Dan) |
1st Jun 2013 12:48pm |
Thanks for the pics kmac, very useful
I'd leave the switch as it is, noone needs to know its not actually a heated seat switch |
1st Jun 2013 1:42pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
How did you get between the underside and the interior?
Merlin |
1st Jun 2013 5:26pm |
Through the opening already there for the existing loom |
1st Jun 2013 6:50pm |
have a look at the pictures just above your recent first posting. I hid the answer in a lot of unnecessary text. |
2nd Jun 2013 7:34am |
Not my highest priority right not but would like to change the icon on the switch - won't have to replace the entire switch - I think the front bits can be replaced
landybehr I tried to google Discovery-2 SLC-Switch without much luck - what is SLC? |
3rd Jun 2013 8:35am |
