![]() | Home > In Car Electronics > The definitive Defender ICE thread |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 ![]() ![]() ![]() |
You're quite right, I miss read that. My apologies.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
Andy S - No probs
![]() With these show Landys that people keep talking about with systems in. Has anyone actually got any pictures? ![]() β½οΈπ’οΈβοΈπ§°πͺ |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
picture's are no good, its the sound quality you want to hear....will get Tim to post some up on his Sponsor's section... Putting Dreams on Drives at JLR Solihull..
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
Hi Peeps,
Can i ask a question please, if i was to change the head unit in my puma to say alpine of Pioneer would i hear the diff in sound quility and loudness etc out of the std speakers? |
Yes you will hear a differance (still no base thou)
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
Until I read this and other similar threads I was satisfied with the standard unit in my DC, but now I have the urge to upgrade!
Could someone be kind enough to advise me if a unit such as the Kenwood KDC-6051U (http://www.justkenwood.co.uk/car-audio.aspx/kdc-6051u-car-radio) is plug and play with the existing connector or do I need one of these adaptors as well (http://www.justkenwood.co.uk/car_radio_adaptors.aspx?id=139)? I assume that I would need a single DIN mounting cage (http://www.justkenwood.co.uk/car-audio.asp...sleeve-new). Thanks! |
Black Wolf - Because the Defender standard radio uses DIN plugs at the rear I HIGHLY doubt you'll need any adaptor at all it should simply be plug and play. With the single DIN cage yes ideally you do need it (although I used mine for ages without) It keeps it secure so no risk of it coming out or loose and also added theft protection also. I fitted mine earlier this year. Worthwhile doing. Be sure to get some Kenwood radio removal keys also otherwise once it's in you won't be able to get it out again
It will also give you better options and functionality for any other add ons you may plan in the future too. Which the LR unit just isn't capable of. TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Thank you!
![]() I thought that was the case but I knew that you would know. |
Your welcome
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
Hi Steve
So ordered 2 pairs of the 1064 speakers and an active sub from justkenwood ![]() Do you know how the sub will connect to the back of a Puma OEM head unit ? I'm guessing it will need a power feed to it ... thinking of mounting it on the back of the cubby box in my TD5 ... where is the best place/lead/colour to wire it in to ? Also if I decide to get some tweeters for the dash, can these be easily wired in or will I need some form of crossover unit ? thanks Jon |
If it's the active Kenwood sub I am thinking of then I think it has RCA input for HU's capable of this and also speaker level too. I don't have one myself so i don't know a great deal however there are members on here that actually have one. Matt, ZeDefender does I think They can then tell you the exact feature it has
![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
I have fitted an Alpine head unit with bluetooth and ipod connectivity etc from my old disco to the 90 and i would like to improve the sound quality so i can listen to a reasonable volume and depth without distortion. I am therefore considering an active sub so have two quick questions:
Is there a significant difference between the Kenwood active sub and the focal unit? Does the Kenwood active sub fit under the seat in an puma xs90 or it there somewhere else to fit? Thanks in advance Darren |
1) It's difficult to say with out hearing both however I would consider comparing the Peak and RMS power of both brands. Each to their own on brand really however I have heard the Kenwood does the job just perfect and also believe it's one of the more powerful ones for it's size. 2) Under the actual seat base - no. However in the seat box it will. On the bulkhead (If you have one) or maybe on the back / underneath or maybe inside the cubby box? (again if you have one) Steve ![]() β½οΈπ’οΈβοΈπ§°πͺ |
