Home > Puma (Tdci) > Power upgrade
Page 1 of 3 123>
landroverdiver
Power upgrade
Hi
I am looking at upgrade options. I want the speed limiter removed and upgrade. Seem to be two options, either remap, or plug in module.
I am a bit wary of getting a remap which could be overwritten by a Dealer upgrade, hence am swaying towards something which can be easily removed and reinstated.
Bell Auto Services seem to offer a good service, and via post. I also picked up Tunit, from an advert in LRO. I could have this fitted locally (Glasgow) which would be attractive.
My truck is a 2007 puma TDCi, used mostly on road carrying 4 guys and loads of heavy dive gear, or for towing.
Any thoughts or recommendations would be welcome.
Mike
Post #15712 21st Sep 2009 8:13pm
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
Im also looking into the same thing, And im being told that pete @ bell auto services is the man for the job! no question.
Post #15715 21st Sep 2009 8:54pm
chay
Wales
Pete's upgrade transform the Puma, are re-mappable at any time and the after service from him is second to none.
Just about the best thing that you could give your Landie.
Apart from Julia Roberts.....
Post #15716 21st Sep 2009 9:16pm
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
Petes re-map tool, before you take it into LR put it back to standard then once they have carried out all the software updates, it shimples, re-map it again!
Not sure if you understand, but basically Petes box allows you to tune it when and where you want, numerous times. 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #15763 22nd Sep 2009 8:27pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Pete's remap works very well, i've no complaints. Clears fault codes as well. 130 crew cab
98 V8 Disco
Post #15768 22nd Sep 2009 11:16pm
lornick
Scotland 1988 Defender 90 300 Tdi HT Epsom Green
Power upgrade
Just had my 90 re-mapped at the weekend and it's made a huge difference to drivability.
Cheviot 4x4 (North Shields) have an tie-in with Bell's Auto Services and did the work for me, whilst also fitting some tree sliders. Great service, very thorough, everything checked and re-checked before they'd let me go.
Drove down from Aberdeen on Friday and returned on Saturday. At the same avaerage speed of 70 mph, on the same road my fuel economy improved by 4.3 mpg (that's 28.7 - 33).
Overtaking between 60-70 mph is simply a matter of putting your foot down now - no need for planning with military precision to get passed that HGV anymore!
Thoroughly recommended mod....... Very Happy
Post #15973 28th Sep 2009 11:43am
AndrewS
BAS is the way forward Thumbs Up
Post #15974 28th Sep 2009 11:46am
cilkorules
Australia
what about upgrading
what about upgrading the turbo slightly larger and intercooler slightly larger then give the computer a tune on the dyno machine,
or you could change the gearing inside the differentials to 3.73:1 giveing a better take off again.
the defender should have a v6 twin turbo diesel engine idealy, thats my opinion or modification and my idea(c)
Post #16312 5th Oct 2009 2:47pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
My vote goes to BAS as well, really improves the 110 (had it on both the new one and the old one) without doubt!
Great after service too.
Post #16318 5th Oct 2009 5:36pm
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
Hi
I have checked the BAS site and things are not entirely clear, at lesat to me.
First, there is no mention of the performance improvement.
Second, what happened if the dealer makes an upgrade on the ECU which has already been tuned? Does the performance upgrade remains or does one has to send the file to BAS for upgrading again?
Thanks
Post #17409 28th Oct 2009 3:43pm
AndrewS
Get a tuning box from Pete and you can add or remove the yourself Thumbs Up
Post #17414 28th Oct 2009 6:20pm
The Boy
My 110 jsut went in for some work and while it was there they downloaded a ecu up grade. All I did was to use the BAS box to read the new down load and email it to BAS and he emailed me back the new tuned file within an hour. I then simply downloaded it back into the ecu. It is back at the dealers on Monday for some more work and before it goes I will put it back to standard (which takes less than 5 minutes).
It pushes out more power than I need but what sells it to me is that I get better mpg than when I run it on standard tune (every bit counts).
Boy
Post #17455 29th Oct 2009 3:40pm
jamesbond007
Ordered the BAS remap last Friday and received the box today.
Hopefully by tonight it should be sssmmmmooookkkkiiinnngggg!........
Post #17899 5th Nov 2009 3:03pm
The Boy
You will be amazed at the change. Enjoy!
Post #17900 5th Nov 2009 3:08pm
Genis
South Africa 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
It doesn't smoke after the remap Very Happy
Pete is great to work with and his BAS box works very well, even from half a world away. I would fully recommend him and his BAS box.
Post #17901 5th Nov 2009 3:28pm
Page 1 of 3 123>
