Fixed my front heated screen by pushing the relay back into its' socket
![]() Hopefully fixed the duff part of my rear heated screen too, with some of that special conductive paint. Time will tell on that one. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Started filling my 90 with Dynamat last night. Dull job and a half.
Howmuch are you gonna be covering with dynamat? Russell
2011MY 110 XS USW Black |
Pretty much anything that I don't need to look through...the quest for great audio and a quieter ride!!
Noisekiller soon as well. |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
We've decided to go for a bit of sound-proofing in my 90 - starting with engine bay and load space and then the rest as an when we are already doing work in those areas.
Got some new Kenwood speakers today (the ones recommended on the Speakers thread) and sub-woofer should be arriving today. ![]() Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
Do you have an amp Pam, as well?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20643 ![]() ![]() |
Greeni,
I think she means the all in one sub like was suggested however I may be wrong.. ![]() I need to clean mine out well soon especially under the seat ect. What would you lot suggest to use to clean the rubber matting in mine? TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Ah yeah...cool.
As for the rubber, I use muc-off and rinse with water and sponge ![]() |
Sounds like a plan.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
My post came out a bit garbled (its been a long week!) - Got 2 of the Kenwards for the front earlier in the week, pleased with them so decided to order 2 more for the back and yeah, the little subwoofer with the built in amp to match. Can't go for anything too big and bulky amp/woofer wise as we are limited on space and where to put it (being as its a 90 and will be packed to the roof nearly when we go to Oz!). Current plan is to mount the sub on the wheel arch behind the drivers seat (no bulkhead). The other side has the ARB compressor on it so that's those 2 spaces filled up ! ![]() Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
still fitting the webasto:
fitted the one-way valve to the expansion tank almost finished the diesel pump install routed the diesel pump wires measured and cut the exhaust and air pipes to correct length and fitted to unit started on orange fan wire ... decided to have a beer instead tomorrow, fit fan wires and fully fit unit on to brackets ... then still loads to do |
Nothing, still stuck in Delhi
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 ![]() ![]() ![]() |
Changed my wipers, then gave it a clean (but to sub-zag standard...
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Used the farm Puma to pick up another quality eBay purchase!
