![]() | Home > Puma (Tdci) > Yeahhh I have variable front wipe washer intermittence |
on the fuses box under the steering wheel there is a RED "relay" (it is the intermittence). take off the red relay and put the new one, game over ![]() |
Thanks dgardel. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
I bought one of these relays secondhand for £5.00 local to me
Now fitted it, works great. Thanks dgardel. Daz110 |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 ![]() ![]() ![]() |
It 'very simple how it works, if I understand you just replace the relay' and function without replacing the command.
![]() 110 Td4 MY07 "E" Keswick Green |
right you said!!!! |
Tatt Member Since: 04 Oct 2008 Location: Was Castleford, now Cape Town! Posts: 47 ![]() ![]() ![]() |
I've also just seen on another forum that this relay is the same one used to make the the rear wiper variable:
"Bosch make a replacement relay with a variable interval, anything from 2 to 45 secs. No wiring or switchgear changes, literally plug & play. Have them both F & R on the 90 (R with 10min wiring mod and original switch). They really are worthwhile, strongly recommended. Bosch p/n is 0 986 335 058, available from Bosch distributors or motor factors, about £14 if I remember rightly." Thanks for the post - I'll try and find what wiring mod is required for the rear wiper and post it here. Tom |
That would be good if you can Tom. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
All
Got the instructions - they relate to a TD5... I'm a bit thick when it comes to attachments - can someone tell me how to do it! Tom |
Vale, togli la frase in cui chiedi scusa per il tuo inglese!!!!!
Vale, delete the phrase about your english..... We speak only "Defenderish" ![]() |
All
Managed to upload a PDF of the instructions. One of the guys on the LR4x4 forum kindly forwarded them to me. Link is here: https://www.defender2.net/gallery/albums/u...0Wiper.pdf Hope it works! Tom |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
Thanks for posting that - I would like to do the rear wiper mod, but sounds like it's the instructions for connecting to the pre-2002 rear wiper knob, but presumably it will work on the later push/push button?
Anyone know the connections, or if there is a relay that can be swapped (like the front wiper mod)? |
Was in the signature, I put the first message. The rose immediately! ![]() put his hands forward like a good Italian ... ![]() 110 Td4 MY07 "E" Keswick Green |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
Last week I was thinking about something like this while I was driving under rain!!!
dgardel I think you can do a big favour to italians Landers if you can report this tips on our forum!! ![]() Tomorrow I will ask to a VW dealers is this is available. Thanks!! ![]() Defender 110 Td4 SE MY 09 |
