Home > Technical > waste gate
Page 1 of 3 123>
Caterham
waste gate
still not got to the bottom of my sh!t running.
to be fair it SEEMS to be running better / well most of the time but definately not all of the time.
seems like fuel starvation to me but when this happens not only is there a definate lack of power but it sounds different too (obviously perhaps?).......
I know this may sound like I'm grasping at straws here - originally I thought it was probably egr and now less convinced about that. do you think there's a chance that the wastegate on the turbo isn't closing properly? how can I tell and would it definately bring up an MIL ?
any thoughts suggestions etc would be very much appreciated.
Thumbs Up
Post #152673 29th Jun 2012 9:21am
Is it constantly running duff or accasionally?
If occasionally, when does it start?
Post #152683 29th Jun 2012 10:07am
Caterham
there appears to be absolutely no ryhme or reason to when it runs well / not well.
symptoms include lack of power / rough / less responsive (making gear changes difficult.
Big Cry Big Cry Big Cry
Post #152686 29th Jun 2012 10:13am
Process of elimination then, what have you checked so far and to what extent?
Post #152690 29th Jun 2012 10:19am
Caterham
tried different fuels ie redex, 2 stroke, bp ultimate etc.
no discernable difference (also problem has been since day 1).
have tried disconnecting egr but no difference.
Post #152691 29th Jun 2012 10:26am
Lorryman100
Waste gate?
The Pumas variable vane turbocharger, fitted to the exhaust manifold, makes it possible to vary the exhaust gas flow of the turbine, dependent on engine operation. This improves the power transfer to the turbine wheel and compressor, particularly at low engine speeds, thus increasing the boost pressure. The guide vanes are opened progressively as the engine speed increases so that the power transfer always remains in balance with the required charger speed and the required boost pressure level. Variable vanes facilitate better use of the exhaust gas energy so as to further improve the efficiency of the turbocharger and thus of the engine, compared to the more conventional 'wastegate control'.
Advantages:
High torque at both high and low engine speeds
Continuous and optimum adjustment for all engine speeds
No wastegate valve required, exhaust energy is better utilised, less back-pressure in conjunction with same
compressor work
Low thermal and mechanical load improves engine power output
Lower emissions
Optimised fuel consumption over the entire engine speed range
A Direct Current (DC) rotary actuator motor operates a drive shaft. The drive shaft is connected to the vanes by an actuating lever. Adjustment of the vanes is achieved by moving the actuating lever. When the drive shaft is turned, a signal is created at the end of the drive shaft; this feedback signal is used to determine the angular position of the vanes. This information is transmitted to the Engine Control Module (ECM).
The turbocharger is designed for fail safe operation. If a fault occurs regarding the control of the unit, the vanes default to the fully open position so as to produce minimum boost. The ECM detects any malfunctions in the stepper motor and generates Diagnostic Trouble Codes (DTC).
http://www.defender2.net/forum/topic13065.html
http://www.defender2.net/forum/topic12511.html
Brian.
Post #152701 29th Jun 2012 11:13am
Caterham
Shocked
Thumbs Up
so its not the waste gate then .....
will have a look at removing the connectors to the filter head as mentioned in post.
will also check connecting rods to vv on turbo make sure they are nice and loose too.
lorryman100 - thanks very much.
Bow down
Post #152707 29th Jun 2012 11:46am
Lorryman100
Let us know how you get on Thumbs Up
Post #152712 29th Jun 2012 12:04pm
Caterham
thank you - and will do.
another job for tomorrow - there's just not enough hours in the day ......and the days are getting shorter again
Big Cry
Post #152716 29th Jun 2012 12:08pm
bell-auto-services
Can you say it does it more when cold or hot ? long run or short runs ?
Pete
Post #152777 29th Jun 2012 6:35pm
Caterham
Pete,
wish I could. there seems to be no consistency what so ever.
Sad
Post #152780 29th Jun 2012 7:05pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I'm assuming it's a puma ?
Look at the connection to the turbo actuator are all the wires ok on the plug
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #152821 29th Jun 2012 10:53pm
Steve
Steve - that's right, there was a recall for a new loom to be fitted Thumbs Up
Post #152830 30th Jun 2012 6:10am
Lorryman100
That was, TECHNICAL SERVICE BULLETIN No.LTB00254/2010 issued on the 20th January 2010. As Caterhams vehicle profile is for a 2011 Puma, chances are it will have the new extended loom fitted from initial build?
Brian.
Post #152850 30th Jun 2012 10:29am
Caterham
had a v quick at loom last night but couldn't find what I was look for Embarassed
funny you mention the wiring though as I've always been v suspicious of the quality - in part because of all the exposes wires (ie not tape wrapped near plugs), also the purle wire in the rear o/s quater (some have use this permanent live for an aux outlet in the rear) had the connector fall off due to corrosion (connector replaced and had just fallen / corroded off again Shocked ), also had an ecu go down and had to be replaced Confused
I did however drain a little off the oil filter last night and disconenct / re-connect pipes (generally all ok - a little crap in the filter - a bit of what looks like silt).
can ran great this morning - I'm tempted to say it ran smoother than I've ever know it too (but that may be wishful thinking will let you know later after driving home again).
Thumbs Up
hope you'ev all had a good weekend?
Post #153196 2nd Jul 2012 6:14am
Page 1 of 3 123>
