Home > My Defender > Mine now - 2003 TD5 90 HT
Page 9 of 24 <123 ... 8910 ... 222324>
bmc054
2002 Defender 90 Td5 HT Tonga Green
Posting
Please continue with the posts /pictures I have a similar 90 and follow your experiences regularly but dont post much myself Shocked
Thanks for sharing Thumbs Up
Post #144090 9th May 2012 10:53am
RRUK
There's always something to do on a Land Rover, so I now have a revised list of things to do over the summer, time permitting:
1. Finish rear floor soundproofing and replace matting
2. Replace duff single tone horn with a twin horn setup
3. Buy and fit a powered sub speaker to add some depth to the Alpine unit
4. Drain and re-fill all fluids in gearbox, transfer box and diffs (for peace of mind)
5. Paint and waxoyl chassis and doors/bulkhead etc
6. Get an auto electrician to connect the heated seats up 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #144118 9th May 2012 12:47pm
RRUK
Haha! I'm famous now Very Happy
http://www.lasalle-trim.co.uk/customergallery
http://www.lasalle-trim.co.uk/comments/reviews 2016 D4 HSE
Post #144160 9th May 2012 4:59pm
Could you not wire up your own heated seats? Or is it more complicated than I'm thinking it is?
Post #144165 9th May 2012 5:08pm
v40mav
Well done - great PR Very Happy Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #144166 9th May 2012 5:14pm
RRUK
Probably, yes, but I want to make sure it's done properly, so may bone up on that, it can't be too hard. 2016 D4 HSE
Post #144252 9th May 2012 8:23pm
RRUK
Today I finished off the sound proofing in the rear tub. Thoroughly cleaned off the floor using some solvent cleaner, and then cut a sheet of the alu' backed foam sound deadening material to size. It's perfect for this as it's 10mm thick, made of closed cell foam so won't absorb moisture or water and is heavy, so it really deadens the panel vibrations.
Once fitted I found the tailor made Land Rover rear rubber mat didn't quite fit, obviously, as the inner dimensions of the tub have been reduced by 20mm. So, I just sliced it up, 2 sections for the wheel boxes and then the floor section.
Once fitted, they are still nice and snug and there's no ripples.
Re glued the rear lower door seal, rubbed down the galv door strip to brighten it up and used new screws to fix it down.
Just been out for a test drive and it has made an excellent difference to the noise reduction. Before, the exhaust noise would boom from under the rear floor, now it doesn't. Now that the entire rear of the Landy and the roof panels have been covered in this stuff, it has made the driving experience much nicer.
Eventually I will also soundproof the seat box, floor, tunnel and bulkhead. I'm also toying with the idea of covering the rear of the bulkhead in some sort of fabric, as well as the curved side panels above the wheel boxes, just not sure what material yet. 2016 D4 HSE
Post #144357 10th May 2012 2:19pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Good man!
Nice to hear its all coming together.
Heated seats - once fitted (yes get a proper bloke to do it Whistle ) you'll never want to go without as they are nice and cosy. I fitted some Exmoor trim ones when I renewed my seats faoms/covers and when eventually wired correctly make a nice difference, even though they look a bit weedy before installation.
Don't know why you didn't get a rangerover to start with (oh yes you did Mr. Green )
Should be good when its all done, but don't make it too nice so you don't want to get it dirty!
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #144386 10th May 2012 4:53pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
You could always fit the Noisekiller front kit and their engine blanket. Well worth it Thumbs Up BM52
Post #144408 10th May 2012 7:22pm
RRUK
Is the engine blanket any good? With the engine having the acoustic cover, my bonnet already soundproofed, I wonder what value it will add?
The interior stuff from Wright Offroad looks the best stuff, I think its the same as the Exmoor moulded version too, but very pricey! 2016 D4 HSE
Post #144413 10th May 2012 7:30pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Makes a fair difference I think. Pricey though, so it depends on how much you value your comfort. It's never going to be a FFRR.... it does make the engine quieter at speed, but this tends to mean you can hear the gears/tyres howling instead Whistle
Post #144415 10th May 2012 7:48pm
bm52
in the Puma you can cruise at 70+ and not hear the engine, the BFGs are quiet, i only hear wind noise. not even that when i am on my own and the music is on. no transmission noise either.
i have the NK bonnet kit which i will fit when it gets dryer and warmer Rolling Eyes it will be interesting to see [hear] whether it makes even more of a difference. BM52
Post #144419 10th May 2012 8:34pm
JOSNOS
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Beautiful Landy and what a good job you have done. Thumbs Up 2003 TD5 90
Post #150531 15th Jun 2012 7:32pm
WelshDefender
Wales
Landy is looking cracking mate. Is that the Flatdog bumper and A bar you have fitted?? If so, how is the quality on them as I am just about to place an order for bumper and A Bar.
Post #150642 16th Jun 2012 5:53pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
[quote="RRUK"]
Probably, yes, but I'd rather get it done properly[/quote
its very very easy, i did it to my gf fiesta zetec s, brought them from a memeber on here, SGH (mps trading)
Post #150655 16th Jun 2012 8:10pm
