Home > Puma (Tdci) > First oil service on Puma |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2633 |
Was this LR Stellenbosch? Usually they are quite good about this sort of thing. Overfill in the gearbox should not have done anything bad, it would just have leaked when the gearbox got hot and the oil expanded, as per the technical bulletin SSM34407 - New Getrag 6 Speed MT82 Transmission - Correct Fill Level, available at: http://landrover.megacloudstorage.com/# -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
2nd May 2012 8:37am |
willemdelange Member Since: 13 Feb 2012 Location: Stellenbosch Posts: 7 |
Good to know - no harm done then. Yes, I service with LR Stellenbosch. Oil must have been factory fill...
2nd May 2012 9:11am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2409 |
Mine also had over 3 liters! and the second gearbox came with ATF Puma 110" SW
2nd May 2012 12:10pm |
Jah, mine came from the factory with the upper tub not secured properly nor was the front axle up to standard, much less the gearbox. Btw, if you want to do in-between engine oil changes, you can get the oil from Lube Marketing (021 511 0574), in Paarden Eiland (http://g.co/maps/sv9d3) -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
2nd May 2012 1:08pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
I changed my Gbox oil very soon after buying it new and 3 litres came out. Must be a factory issue. I don't think that would be a major surprise when you hear all the other problems that have been assembly related !
2nd May 2012 8:52pm |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 |
Willem
If you're doing a lot of gravel travel you should consider changing your engine oil every 10k instead of the mandated 20k. Especially if you're filling up with 500ppm diesel. |
3rd May 2012 5:16am |
I do 10Kkm oil changes regardless, and also after every overlanding trip. I also use 2SO with every tank -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
3rd May 2012 5:18am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Daniele’s site is great. A lot to read!
What’s interesting is that on page 880 of the document “2010.06_Defender_MY07_on_Workshop_Manual_Complete.pdf” it says that the instrument cluster has an indicator on the left hand side, in the blank screen, that lights when the transfer box is in the low range. Look for item 24 “Transfer box low range indicator”. I’ve never seen this illuminated, even when new. I wonder when this was introduced and if it is installed on anyone’s Defender. BTW anyone know what item 7 is “High ECT indicator”, on the top panel. Merlin |
3rd May 2012 9:39am |
Never seen it illuminated either, whether in a V8, 2.8i, 300Tdi, Td5 or Puma -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
3rd May 2012 9:46am |
Engine Coolant Temperature. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
3rd May 2012 9:59am |
Doh! Bl**ding obvious when you know. Thanks. Can’t get into Daniele’s site now, can you? I.e.: http://landrover.megacloudstorage.com/#
merlin |
3rd May 2012 10:11am |
2SO+10000Kkm interval is not a good combination if you use 913A/913B oil. WIth 913C, maybe it would last longer. Puma 110" SW ............................................................. Earth first. Other planets later |
3rd May 2012 12:54pm |
Thanks for all the useful info on the oil change intervals - 20000km is quite long for the dusty southern Africa conditions. Yes, we tow a lot and yes we do at least two overland trips a year (Nam, Bots, Ang, Zam and Zim!) – my landy is new and I have changed my engine oil (not diffs and gearbox) at 10000km, I guess it would be good idea to get into the habit of changing diffs + t-case + gearbox + engine every 10000km regardless). I use 50ppm diesel with a dose (200ml) of 2SO (JASO FB) every second/third tank of diesel (I do not bother with 2SO if I fill up with 500ppm in Nam, Bots, Zim and Zam)
4th May 2012 5:44am |
Willem, each to their own, but I think every 10k for the diffs etc is overdoing it. LR recommend 80k for diffs and t box, and 160k for g box. I've decided to cut that in half, as well as replacing air filters and fuel filters every 20k. I don't do a lot of towing though.
4th May 2012 8:02am |
