Home > Puma (Tdci) > Softening the Ride on my 110 USW
MartinK
I have a 110 USW, and (for my needs) the rear end is too stiff. Ride is OK when fully loaded, but for the vast majority of the time I don't carry that much gear (kayaks, mountain bikes etc). SWMBO complains about the "choppy ride"...
So...my question is... Is the best way to soften the rear end to put lower grade springs in?
MK posted this table some time ago...but I'm not really sure what to make of it!
This has raised a few questions:
1. From the research I have seen, it appears as though the springs are colour-coded in some way. So I assume I can find the spec of the springs on my 110, and then get one "grade" lower?
2. Are they easy to fit?
3. I'll use LR springs (rather than terrafiorma etc) because I want the vehicle to be as standard as it can be whilst under warranty (and so as not to need to notify my insurance).
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #141082 23rd Apr 2012 11:46am
MK
Me again. I agree, you should find the colour code on yours first.
It is quite easy to remove and fit new ones. You need to drop the axle by lifting the chassis and body. Be safe. Puma 110" SW
Post #141101 23rd Apr 2012 12:56pm
Captain Speaking
2008 Defender 90 Puma 2.4 CSW Tonga Green
[/quote]It is quite easy to remove and fit new ones. You need to drop the axle by lifting the chassis and body[quote]
Rolling with laughter
Post #142317 28th Apr 2012 11:37pm
Captain Speaking
Post #142318 28th Apr 2012 11:39pm
Mountain_man
Wales
Is yours a post or pre 2011 model? Previous to this date they were (apparently) fitted with purple/brown progressive springs and afterwards with white/green/green springs - which my mate, who has had both, reports are a far better ride on the utility wagon
CSW RHD 110 7 Seat (3050kg) RKB500300 White/green/green 422.96mm
RHD 110 Utility RKB101111 Purple/Brown 409.96mm
The info from LR is not clear but if you are on brown/purples then some white/green/greens may improve the ride. If you asre already on W/G/G then options are probably aftermarket only or earlier springs which won't be progressive.
Post #142329 29th Apr 2012 8:30am
Mountain_man
Wales
Road spring data
Road spring Part number Colour code
90 2 seat utility (2400 Kg)
Front - Driver's side REB500200 Red/green/white
Front - Passenger side REB500220 Red/green/orange
Rear - Driver's side NRC 9448 Blue/red
Rear - Passenger side NRC 9449 Yellow/white
90 2 seat utility (2550 Kg)
Rear - Driver's side RKB101230 Green/yellow/red
Rear - Passenger side RKB101240 Green/yellow/white
90 4 seat station wagon (2400 Kg)
Rear - Driver's side RKB500290 Red/green/green
Rear - Passenger side RKB500280 Red/green/red
90 4 seat station wagon (2550 Kg)
Rear - Driver's side RKB500270 White/green/pink
Rear - Passenger side RKB500310 White/green/purple
LHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg)
Front - Driver's side NRC 8044 White/white
Front - Passenger side NRC 8045 Yellow/yellow
Rear - Both sides RKB101111 Purple/brown
RHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg)
Front - Both sides NRC 8045 Yellow/yellow
LHD 110 7 seat station wagon (3050 Kg)
Rear - Both sides RKB500300 White/green/green
RHD 110 7 seat station wagon (3050 Kg)
110 heavy duty and all 130 (3500Kg)
Front - Driver's side NRC 9448 Blue/red
Front - Passenger side NRC 9449 Yellow/white
Rear - Both sides 78 of 1212 RKB101111 Purple/brown
Post #142331 29th Apr 2012 8:31am
MartinK
Mountain-man - terriffic advice, thanks, I'll look under today once it stops raining! Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #142537 30th Apr 2012 7:44am
MartinK
Finally got around to cleaning-off the Dinitrol with white spirit.
The springs on my Defender are indeed Purple/Brown (although the brown looks more like dark yellow, but never mind!).
The new RKB500300 (White/green/green) are £66.76 each (+VAT) from most dealers! I have seen them for as little as £48 on the web)
Anyone:
1. Done this, and confirm that white/green/green will actually noticably soften the ride (remembering driving a CSW, I DO think they are softer/more compliant at the back end...)
2. Anyone got any white/green/green for sale because they've lifted or hardened the back end?
Thanks Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #146219 21st May 2012 9:35am
110SEB
Wouldn't it be easier to get a new Mrs, Martin? No Mrs and the 'choppy ride' issue will vanish over night.
Post #146223 21st May 2012 10:17am
MartinK
The springs are cheaper to swap than the wife!!!! Shocked Whistle Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #146224 21st May 2012 10:18am
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
A couple of bags of sand Thumbs Up
Post #146254 21st May 2012 1:27pm
T1G UP
i towed my trailer yesterday. about 80 kg nose weight. made the ride lovely.
Also i have removed my 6&7 seats...they weigh around 30kg each. so i think the load over the rear axle has been reduced by say 60-80 kg.
Whats the weight over the rear axle for a late 110?
Post #146258 21st May 2012 1:47pm
MartinK
T1G UP
I'm not sure of weights, but as mine's a County USW, it's quite a lot lighter than a CSW XS - no rear seats, no aircon, etc.
Mine's great when well-laden, but "choppy" and bouncy unladen.
I'm rarely fully-laden (if I need to carry a lot I use the trailer...it's easier to load)...Hence this thread.
When I drove CSW's in the past, they seemed less choppy at the back, hence this thread... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #146260 21st May 2012 1:59pm
T1G UP
well empty mines harsh...handles great!
think air rides where its at!
Post #146275 21st May 2012 4:17pm
MartinK
Well - I have done a deal with a site sponsor (Duckworths, Thanks Dan...), to buy the CSW springs.
I'll write-up a report on fitting, and on findings... Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #146276 21st May 2012 4:22pm
