![]() | Home > Puma (Tdci) > Softening the Ride on my 110 USW |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Hey guys,
Last week i bought pair of rear springs for my 110 SW puma from ebay uk and i am yet to receive them. It says white green green but could anybody confirm that they are RKB500300 please? http://www.ebay.co.uk/itm/231034096874?ssP...1423.l2649 Many thanks. Regards, Diluk |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
Well, RKB500300 is indeed White/Green/Green. If you already have a standard SW, then these should be the same as fitted... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Thanks for the post MartinK. Well when i checked my currently fitted rear ones, it was purple brown (Same for crew cab and utility 110 i guess). So hope my green and white ones will give me a better ride? Cheers!
Aha - ok I thought you has a SW (as per your avatar)
I did the same as you. The new ones are slightly longer, but do weem to offer a slightly better ride. However the vehicle will be even more jacked-up at the back unladen because of the slightly longer springs - see comparison here: ![]() Click image to enlarge I haven't adjusted my headlamps' dip beam yet, but that's now set a bit low because of the higher rear end. One day I'll buy some -1" springs to put the ride height back, and make the rear end a bit less "jacked-up". The Koni shocks combined with the new springs was a vast improvement ![]() |
Hello martinK, I do not mind the raised back. I hope it will have some more ground clearance also. Have you actually gone through my ebay link. Please check. Appreciate if you could confirm that they are RKB500300. Many Thanks.
regards, Diluk |
Yesterday i change my rear 110 brown purple to white green green coil springs and i noticed much better ride. Did not really notice any raised back.
Regards, Diluk |
