Home > Maintenance & Modifications > Type approved 2" rear receiver for towing
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Does anyone know is a type approved 2" rear receiver exists? My plan is to replace the standard LR towbar with one and get a front guard/receiver and then a winch on a 2" receiver tray so it can be used either end. I would probably fir some form of socket on the battery box and trail a power cable when used. This would be for very occasional use.
I know that actually my 2012 Utility is N1 and so doesn't have to have a type approved tow bar but I worry it would just make things simpler in the event of an incident if it was.
Thanks
Craig 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #135416 29th Mar 2012 11:17am
I don't think one does exist. I understand that the type approval process is very expensive, which makes it unviable for what is essentially a niche product. Darren
Post #135462 29th Mar 2012 3:31pm
leeds
i do not know of any type approved 2" receiver.
However I do understand it is possible to get individual 2" receiver approved
I understand that there is a tow bar supplier in Halifax who can do individual approval.
Please note I do not know the above for fact but is what I have heard.
Brendan
Post #135547 29th Mar 2012 7:55pm
LRSoffroad
I sell alot of 2" receivers and havent come across one that is approved as yet i think the cut off date for type approval was 98/99 when the TD5 was introduced
Post #135569 29th Mar 2012 8:49pm
T1G UP
well in my experience its best to stick to the LR approved and supplied tow gear.
Post #135605 29th Mar 2012 11:34pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Land Rover actually supply a 2" receiver, its only available for foreign markets, because its not UK type approved Big Cry Richard
Either a 90, 110 or 130.
Discovery 5
Post #135607 29th Mar 2012 11:59pm
barjout
Canada 1996 Defender 110 300 Tdi SW Alpine White
Terrafirma makes one. Baught one from Belgium lat year.
Post #135609 30th Mar 2012 3:48am
Buying them isn't the issue. It's using them legally for towing that's the problem. Darren
Post #135625 30th Mar 2012 7:25am
A definate NO GO legally if you use it for towing on the road ..... Sad
If it's mainly for a demountable winch why not use an an 'adapted' adjustable Dixon Bate type towbar ....
Post #135638 30th Mar 2012 8:56am
mrandmrsh
I liked the idea of having the same mount front and rear but your idea may work I guess - get a DB adjustable height tow bar on the rear like this
Then get some form of fabricated winch mount on a spare slider?
I did think however that non type-approved tow-bars were legal on N1 vehicles?
C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
Post #135646 30th Mar 2012 9:23am
That's it, but you could still have the 2" receiver 'set' into the sliding bit so that it would be the same as the front and then switch to standard ball for all other times.
Although you don't have to have a type approved mount it still needs to be legal from the 'form of construction' point of view and 2" receivers are not as I understand it
Post #135649 30th Mar 2012 9:29am
I take it all back !
Read this (specifically the bit under the picture of the black framework) ....
http://www.watling-towbars.co.uk/import_vehicle_towbars.html
Post #135650 30th Mar 2012 9:31am
JWL
I'm only following this thread out of mild curiosity but the way I read that caveat is that the American electric brake set up is not approved here in the UK as are the two ball sizes of hitches. We've come a long way since the 2" ball size was phased out in this country back in the 70's in favour of having a standardised 50mm ball.
Post #135652 30th Mar 2012 9:42am
