Home > Puma (Tdci) > Metallic Rattle and other sounds |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
4 the second one I would look into the pressure sensor/valve on the common rail system. Puma 110" SW
1st Mar 2012 3:46pm |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 |
thsnks MK
is that something i can do myself or is it a dealer job? |
1st Mar 2012 4:37pm |
If that is the case it defenetly a non DIY work. As for the other noise, search here under rattle+turbo or heat shield. Puma 110" SW
1st Mar 2012 6:43pm |
cheers MK, that's one for the morning.
1st Mar 2012 7:21pm |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 |
My fix for the heatshield rattle was to insert 3 small stainelss nuts between the shield and the rail it attaches to to lift the whole shield away from the manifold. Re-use the original bolts and you're done. Just make sure the mechanic that does your service doesn't take it upon himself to remove them thinking he's helping D300 HSE 110
2nd Mar 2012 9:45am |
