Home > Puma (Tdci) > Metallic Rattle and other sounds
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
My Puma 2.4 has developed a couple of noises.
the first noise is a metaillic rattle that sounds a bit like a 'ringing' sound. it is quite high pitched, not very loud and very intermittant. i only hear it when the engine is idling.
the second noise is from the engine. on idle (at traffic lights for instance) the engine seems to cyle through two definite running sounds, one is smooth as you would expect and then this gradually turns rough and the noise level increases and then fades away.
any clues for either of these?
the vehicle has covered 4500 miles.
Post #127988 1st Mar 2012 3:01pm
MK
4 the second one I would look into the pressure sensor/valve on the common rail system. Puma 110" SW
Post #127998 1st Mar 2012 3:46pm
shaun.mobile
thsnks MK
is that something i can do myself or is it a dealer job?
Post #128010 1st Mar 2012 4:37pm
MK
If that is the case it defenetly a non DIY work. As for the other noise, search here under rattle+turbo or heat shield. Puma 110" SW
Post #128051 1st Mar 2012 6:43pm
shaun.mobile
cheers MK, that's one for the morning. Thumbs Up
Post #128061 1st Mar 2012 7:21pm
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
My fix for the heatshield rattle was to insert 3 small stainelss nuts between the shield and the rail it attaches to to lift the whole shield away from the manifold. Re-use the original bolts and you're done. Just make sure the mechanic that does your service doesn't take it upon himself to remove them thinking he's helping Rolling Eyes D300 HSE 110
Post #128191 2nd Mar 2012 9:45am
