Home > Puma (Tdci) > Screaming Turbo when Hot
Page 1 of 4 1234>
BruceT
South Africa
Hi all,
Not sure how to discribe this, but after a long trip when my vehicle is hot there is a screaming noise when pulling away in first and 2nd gear.
Doesnt do it any other time. Only when I have done a few hundred kms of highway cruising.
It definately sounds like its related to the turbo.
Any ideas what it could be?
(its a MY11 Puma 110 with 37k kms on it)
Thank you
Post #127023 27th Feb 2012 11:41am
RED-DOT
A leaking intercooler hose?? I had a hoseclip snap on my TD5 and i changed them all for a better make. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #127037 27th Feb 2012 12:13pm
BruceT
South Africa
No doesnt sound like that and only does it after long trips. Sitting in traffic and short trips - no sound.
Post #127039 27th Feb 2012 12:15pm
Could be the early stages of a split in the pipe from turbo to intercooler. The pipe is softer when hot.
Mine did something similar as it started to wear through on the steering column lower clamp bolt.
Post #127060 27th Feb 2012 12:45pm
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Bruce,
Not something to do with the viscous fan?
I've had my turbo make an odd noise once. I was towing another Defender on a flatbed trailer at about 1600m above sea-level going up a steep incline, and had done about 400km already, so the turbo was working hard. There was a definite screeching sound from what I thought was the turbo for about 10 seconds, almost as though there was no oil in it. Haven't heard it again, though (and hoping I don't either). Asked for the turbo to be checked at the next service, clean bill of health (for what it's worth).
Post #127061 27th Feb 2012 12:46pm
Lorryman100
Take off the turbo heat shield and check the turbo/manifold gasket for signs of soot. It seems to be a common occurrence on the Puma for the Turbo manifold to warp and allow the exhaust gases to vent out through the now defunct gasket. If this is the case then Nakatanenga (site sponsor) can supply you with an annealed copper gasket which moulds itself to the warp and reseals the join. If the Turbo manifold is OK then it is probably an intercooler pipe that is causing the scream. Check all joints and that none of the hoses are holed anywhere, there is a service bulletin ref a plastic stud on the inner face of the wheel arch line that over time holes the nearby intercooler pipe:
I recently had a squeal on my Puma, but only when hot, which sounded like a slipping fan belt? After a bit of investigation it turned out to be a loose pipe clip on the turbo hose causing the pipe to make it's way off the turbo. After repositioning the pipe onto the Turbo, and doing up the pipe clip tightly, the squealing sound has now gone.
HTH Brian.
Post #127066 27th Feb 2012 12:54pm
BruceT
South Africa
Thank you for the replies. The fan belt slip describes the sound more closely. Its definately not a loose or split boost pipe.
What is confusing is that it only happens sometimes. I towed a heavy xplorer (caravan) down to Mosselbay in December. Did the trip in 14 or so hours in one go. No squeal, but when I did the return tripthere was the squeal for a short while until the vehicle seemed to cool down.
It is almost due for a service now and is under warrenty so will get the stealer to check.
Thanks again for the replies.
Post #127073 27th Feb 2012 1:05pm
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Sounds like a leaking turbo to manifold gasket, it's a metal type gasket, had the same problem with mine , it sounded like a police siren.
Cheers Ash.
Post #127086 27th Feb 2012 1:57pm
BruceT
South Africa
Ash did yours scream all the time or only when hot?
Post #127090 27th Feb 2012 2:04pm
ZeDefender
Same question from me Very Happy
Mine does it all the time from cold around 2000 rpm (another issue for the first service Rolling Eyes )
Cheers,
Matt Tell someone you love them today because life is short.
Post #127098 27th Feb 2012 2:24pm
Eduardo
Same is mine some time ago.
Turned to be a the manifold gasket. Were most audible over the 2000 RPM in all conditiosn (hot/cold)
Cheers Eduardo
Post #127106 27th Feb 2012 2:43pm
ZeDefender
Cheers Eduardo - just need to convince LR to use the Nakatanenga gasket under warranty Whistle Tell someone you love them today because life is short.
Post #127132 27th Feb 2012 4:04pm
Landyash
Hi BruceT mine did it hot all cold,me bčing a tight git fitted the standard one.
If its only when hot some thing is expanding might be a cracked manifold Sad
Good look Smile
Post #127139 27th Feb 2012 4:30pm
Lorryman100
After reading the above posts I decided to go outside and remove the turbo heat shield and have a poke about looking for any soot deposits around the Turbo manifold/Exhaust manifold, I did not find any. If the turbo manifold is clean, then I would be double checking all the intercooler hoses again just to make sure that is not the cause. Thumbs Up
The black smudges you can see on the join are from my dirty fingers when I ran them over the joint as it appears the Turbo is not tightly secured? It is, as I could not get any movement on the nuts. Whistle
The cause of the squealing on my Puma was the pipe clip being loose and you can see the before and after pics below.
HTH Brian.
Post #127142 27th Feb 2012 4:32pm
jst
i had these symptons too, there is a post here somewhere about it.
all hoses are good, no soot marks found etc.
in the end i put it down to the viscous fan. if i can find the thread i will link it in as it describes the symptons in more detail.
Mine is yet to repeat it since the initial post i put up. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #127229 27th Feb 2012 8:02pm
Page 1 of 4 1234>
