Home > Maintenance & Modifications > Your 5 Top Modifications
Page 3 of 9 <123456789>
ericvv
[quote="bpman"][quote="The Musketeer"]
bpman wrote:
mine are:
gents ...
5. Entreq Fuel Cooler Guard .. protects the vunerable fuel cooler and other bit from stones
BPman, the Entreq fuel cooler guard, did you buy the version with, or without stabilizer? Could you install it yourself easily, or is the a job for Autobritt here?
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #123732 13th Feb 2012 8:30pm
ericvv wrote:
The Musketeer wrote:
bpman wrote:
mine are:
3. crystals + h4 PIAAs
4. parrot ICE
5. entreq FCG
I have no idea what they are... I assume 3 is something to do with lights? Shocked
don't think it is this parrot ICE, no?
http://www.google.ch/imgres?q=parrot+ice&a...29,r:2,s:0
or this one?
http://www.google.ch/imgres?q=parrot+ice&a...amp;zoom=1
Ericvv ... parrot ice ...
Entreq fuel cooler guard - stabiliser means anti-roll bar - yes I bought with stabiliser, easy to fit but you need a rivnut tool and dinitrol to do a good job. PM me and I will send you photos and info.
bp
Post #123741 13th Feb 2012 8:46pm
Laurie
This is Parrot ICE.....
Post #123743 13th Feb 2012 8:54pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Laughing Laughing Laughing Laughing
Post #123744 13th Feb 2012 8:55pm
Ravers
Mine: Privacy glass
Tow pack
Roof mounted stowage nets
Stainless steel bolts externall
Rear matt for the dog
farmer giles wrote:
top 5 for my family life puma 110 are:
1. sub, amp, mids and tweeters + ipod head unit stereo
2. rear nas step
3. variable wiper relay
4. rear door power strut
5. spotlights to "encourage" oncoming drivers to dip their lights
top 5 for my single life td5 90
1. sub, amp, mids and tweeters +ipod head unit
2. J E Engineering remap and intercooler
3. twisted performance sports exhaust
4. koni suspension 1" drop
5. j e engineering spotlights in grille
Hi FG
Is the variable wiper relay for the rear wiper?
Just wondering as Im always switching the rear wiper on & off Sad Ravers
Post #125992 22nd Feb 2012 8:38pm
2. rear nas step
Hi FG
to get the rear wiper to run delayed - I used the front wiper relay when I replaced it with the programmable variable relay for the front wipers ... does that make sense ?
Post #125995 22nd Feb 2012 8:44pm
Ravers
bpman wrote:
2. rear nas step
Hi FG
Ahhh yes. Thought about doing it for ages, was it a complicated job? I'm not into ripping the new defender to bits just yet. Thanks Ravers
Post #126001 22nd Feb 2012 8:50pm
Ravers wrote:
bpman wrote:
2. rear nas step
Hi FG
to install the front wiper delay relay is easy, but the rear relay needs a few wire changes, do a search on the forum for more details. dgardel is the wiring king !
Post #126037 22nd Feb 2012 10:18pm
farmer giles
cheers BP, i was a bit slow in responding to that query (and you have answered it better than i would of). Thumbs Up
Post #126092 23rd Feb 2012 10:17am
dgardel
Italy
Embarassed
For normal intermittence (using the OLD front Land Rover relay)
VERY EASY MOD!!!!
Have you a standard/original Land Rover wiper ECU in your hand?
The green-white cable of position 6 of the base must be put on position 1
Test it..............................
..............job done
FOR A MORE REFINED SOLUTION, Thank you to BarneyRubble for adding the VW variable timer to the rear wiper
download here the BarneyRubble pdf
Works like the front - press the switch, let it wipe, switch it off, wait until you want it to wipe again, switch it on, and leave it - the wipers operate on intermit at the time you left between switching off and back on again.
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #126093 23rd Feb 2012 10:21am
ZeDefender
It's an interesting mod (just up my street) but I hardly ever use the rear wiper anyway - not much point, since the security grill makes the window redundant Laughing Tell someone you love them today because life is short.
Post #126094 23rd Feb 2012 10:21am
dgardel
Italy
Modded my previous post with TWO solution............. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #126096 23rd Feb 2012 10:28am
ZeDefender
Why use the extra black wire? Is the green/white one too short or can't you fish the connector out of the block?
Sorry if that's a stupid question Embarassed
Matt Tell someone you love them today because life is short.
Post #126098 23rd Feb 2012 10:36am
dgardel
Italy
Moving the cable on the new position you need to change the pin (it is smaller).
I build the black one for do not modify the original harness Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #126100 23rd Feb 2012 10:56am
ZeDefender
Aha Thumbs Up
Post #126101 23rd Feb 2012 11:03am
